Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓The HP c010 series features socketed RAM, leaving the end-user the ability to upgrade to a max of 8GBs using DDR3 SODIMM sticks. This can provide a significant performance boost, especially if the PC is struggling with browsing the web or tasks that require significant memory usage.
This guide is meant to guide end-users when upgrading the RAM of the system
Before starting, please ensure the computer is powered off and unplugged from its power source
Carefully rotate unit so that its "foot" assembly is facing up, as shown in the photo
Unscrew the two #2 philips screws with a screwdriver
Remove the foot from the unit
Carefully use a guitar pick or similar opening device to separate the two halves of the display assembly at the seam
Remove the display from the other half of the computer, set to the side
Locate the RAM slots near the CPU cooling assembly on the motherboard
Press in the retaining tabs to release the memory for removal
Slot in a new stick at a 45° angle, and press down until a click is heard
