HP 17-x173dx RAM Replacement
    1. HP 17-x173dx RAM Replacement, Battery: step 1, image 1 of 2 HP 17-x173dx RAM Replacement, Battery: step 1, image 2 of 2
      • Begin by sliding the left tab to the unlock position
      Ask FixBot
    2. HP 17-x173dx RAM Replacement: step 2, image 1 of 1
      • Push each of the two tabs in the direction specified by the picture.
      Ask FixBot
    3. HP 17-x173dx RAM Replacement: step 3, image 1 of 3 HP 17-x173dx RAM Replacement: step 3, image 2 of 3 HP 17-x173dx RAM Replacement: step 3, image 3 of 3
      • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
      Ask FixBot
    1. HP 17-x173dx RAM Replacement, RAM: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, remove fourteen 7 mm screws on the back of the device (two will be underneath where the battery was).
      Ask FixBot
    2. HP 17-x173dx RAM Replacement: step 5, image 1 of 3 HP 17-x173dx RAM Replacement: step 5, image 2 of 3 HP 17-x173dx RAM Replacement: step 5, image 3 of 3
      • Remove the Optical Disk Drive.
      • Use the spudger to lift the plastic backing, starting from the back right side, near the vent.
      • Remove the back of the device by continuing to lift the plastic around the entire perimeter of the device.
      Ask FixBot
    3. HP 17-x173dx RAM Replacement: step 6, image 1 of 3 HP 17-x173dx RAM Replacement: step 6, image 2 of 3 HP 17-x173dx RAM Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingernails to carefully pry the two metal retention clips out and away from the ram casing.
      • Then gently bend the plastic retainers away to free the ram stick.
      Ask FixBot
    4. HP 17-x173dx RAM Replacement: step 7, image 1 of 2 HP 17-x173dx RAM Replacement: step 7, image 2 of 2
      • Lift the RAM stick away from the motherboard and remove it from the device.
      • Repeat this step for any extra sticks of RAM.
      Ask FixBot
Install your replacement RAM and reassemble your device by following these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 65
All Time: 1,354
