HP 17-x116dx RAM Replacement
    1. HP 17-x116dx RAM Replacement, RAM: step 1, image 1 of 2 HP 17-x116dx RAM Replacement, RAM: step 1, image 2 of 2
      • Turn off your computer before starting, and remove the battery.
      • Locate all 8mm screws on the back of the computer and remove them with the Phillips #1 screwdriver.
      Ask FixBot
    2. HP 17-x116dx RAM Replacement: step 2, image 1 of 3 HP 17-x116dx RAM Replacement: step 2, image 2 of 3 HP 17-x116dx RAM Replacement: step 2, image 3 of 3
      • Remove the optical drive by pushing it in and then it will pop out.
      Ask FixBot
    3. HP 17-x116dx RAM Replacement: step 3, image 1 of 3 HP 17-x116dx RAM Replacement: step 3, image 2 of 3 HP 17-x116dx RAM Replacement: step 3, image 3 of 3
      • Use a spudger to remove the back panel.
      Ask FixBot
    4. HP 17-x116dx RAM Replacement: step 4, image 1 of 3 HP 17-x116dx RAM Replacement: step 4, image 2 of 3 HP 17-x116dx RAM Replacement: step 4, image 3 of 3
      • Once you remove the back panel, locate the RAM.
      • Use your fingernails to release the clips holding the memory by pulling them away from the RAM.
      Ask FixBot
    5. HP 17-x116dx RAM Replacement: step 5, image 1 of 2 HP 17-x116dx RAM Replacement: step 5, image 2 of 2
      • The RAM will pop out, and you can remove it.
      Ask FixBot
4 other people completed this guide.
Sarah Coral
346 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 69
All Time: 3,058
