Up to 20% off select tools
HP 17-x061nr Disassembly
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
143
All Time:
10,907
Comments: 3
3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you are planning on replacing any of the internal components of your HP 17-x061nr laptop then you will need to remove the back. This particular laptop is built with a solid back cover that the keyboard and internal components are seated into. There are a lot of screws that hold the laptop together including 2 that are hidden under the rubber footrests. Pay careful attention to this guide and you will have your laptop disassembled and be able to replace any internal components easily.
    1. HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: step 1, image 1 of 3 HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: step 1, image 2 of 3 HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: step 1, image 3 of 3
      • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
      Ask FixBot
    2. HP 17-x061nr  Disassembly: step 2, image 1 of 2 HP 17-x061nr  Disassembly: step 2, image 2 of 2
      • Peel back the rubber footrests located next to the battery, on the left and right sides.
      • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
      Ask FixBot
    3. HP 17-x061nr  Disassembly: step 3, image 1 of 1
      • Slide the optical drive out and away from the laptop.
      Ask FixBot
    4. HP 17-x061nr  Disassembly: step 4, image 1 of 3 HP 17-x061nr  Disassembly: step 4, image 2 of 3 HP 17-x061nr  Disassembly: step 4, image 3 of 3
      • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
      • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
      • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
      Ask FixBot
7 other people completed this guide.
Author
with
Michael hansen
427 Reputation
1 Guide authored
3 Guide Comments
I have a 17-x051nr but the steps are exactly the same. Thank you! (I never like peeling off the bottom feet unless I know for sure there’s a screw under there)
Frank Buccella - Reply Share
i searched all over for how to do this with my 17 inch HP Elite Notebook. Your instructions were perfect! Thank you!
Bud Hines - Reply Share
Thank you! Also worked for HP-14AN013NA
Martyn Jones - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 143
All Time: 10,907
