HP 17-p051no Hard Drive Upgrade
    1. HP 17-p051no Hard Drive Upgrade, Disconnect the battery: step 1, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Disconnect the battery: step 1, image 2 of 2
      • Put the laptop upside down and remove the battery by pulling the right latch outward.
      • Raise the battery upwards.
      Ask FixBot
    2. HP 17-p051no Hard Drive Upgrade, Remove screws from the base: step 2, image 1 of 1
      • Remove the circled screws with a Phillips #0 screwdriver.
      • Note that only circled points include a screw. There aren't screw in all holes.
      Ask FixBot
    3. HP 17-p051no Hard Drive Upgrade, Remove the paws and the screws under them: step 3, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Remove the paws and the screws under them: step 3, image 2 of 2
      • Remove the paw with iFixit Opening Picks.
      • Remove the screw with a Phillips #0 screwdriver.
      • Do the same operation to the right corner.
      Ask FixBot
    4. HP 17-p051no Hard Drive Upgrade, Remove the corner pieces: step 4, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Remove the corner pieces: step 4, image 2 of 2
      • Remove the corner piece with iFixit Opening Picks.
      • Remove the screw as shown in the picture.
      Ask FixBot
    5. HP 17-p051no Hard Drive Upgrade, Remove the optical disk drive and the screws: step 5, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Remove the optical disk drive and the screws: step 5, image 2 of 2
      • Pull the optical disk drive (ODD) out with fingers.
      • Remove the screws as shown in the picture.
      Ask FixBot
    6. HP 17-p051no Hard Drive Upgrade, Remove the keyboard/touchpad: step 6, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Remove the keyboard/touchpad: step 6, image 2 of 2
      • Remove the keyboard/touchpad tile with iFixit Opening Picks and fingers.
      • Remove the cabels as shown in the picture from the motherboard.
      • Now you can start the replacement or cleaning operation.
      Ask FixBot
    1. HP 17-p051no Hard Drive Upgrade, Remove the overheading cable: step 7, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Remove the overheading cable: step 7, image 2 of 2
      • Turn the cable's tip upwards and put the cable out of the way.
      • Remove the buttresses from both sides of the hard drive.
      Ask FixBot
    2. HP 17-p051no Hard Drive Upgrade, Upgrade the hard drive: step 8, image 1 of 2 HP 17-p051no Hard Drive Upgrade, Upgrade the hard drive: step 8, image 2 of 2
      • Remove the SATA cable from the old hard drive.
      • Plug the SATA cable to the new hard drive.
      • Put all of the removed pieces and screws back and reassembly the laptop.
      Ask FixBot
This is good guide for you if you are planning to upgrading a SSD on this laptop.
Hiiri522
593 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 309
