HP 17-ca1022cy Hard Drive Replacement
    1. HP 17-ca1022cy Hard Drive Replacement, Remove bottom screws: step 1, image 1 of 1
      • To remove the bottom panel there are 9 screws (in yellow) on the back and two screws under the disk drive. The disk drive screw is in the red circle.
      • You'll have to remove the rubber feet to access 6 of them
      Ask FixBot
    2. HP 17-ca1022cy Hard Drive Replacement, Remove drive bay: step 2, image 1 of 2 HP 17-ca1022cy Hard Drive Replacement, Remove drive bay: step 2, image 2 of 2
      • Once you remove the disk drive screw (blue circle), the drive should slide out of the chassis.
      • Under the drive bay there are two screws to remove.
      Ask FixBot
    3. HP 17-ca1022cy Hard Drive Replacement, Pry off the top chassis: step 3, image 1 of 2 HP 17-ca1022cy Hard Drive Replacement, Pry off the top chassis: step 3, image 2 of 2
      • Slip a thin prying tool in the seam between the top and bottom shells and work your way around the frame.
      Ask FixBot
    4. HP 17-ca1022cy Hard Drive Replacement, Motherboard: step 4, image 1 of 1
      • Picture of the motherboard
      Ask FixBot
      • Pull up on the connector side of the drive, then pull toward the battery, taking care not to tear it.
      Ask FixBot
Anadyr Elliott
165 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 839
