HP 17-bs049dx USB Port Replacement
    1. HP 17-bs049dx USB Port Replacement, Battery: step 1, image 1 of 1
      • To remove the battery, simply push the tabs towards each other.
      • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
      Ask FixBot
    1. HP 17-bs049dx USB Port Replacement, Back Panel: step 2, image 1 of 1
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
      Ask FixBot
    2. HP 17-bs049dx USB Port Replacement: step 3, image 1 of 1
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
      Ask FixBot
    3. HP 17-bs049dx USB Port Replacement: step 4, image 1 of 2 HP 17-bs049dx USB Port Replacement: step 4, image 2 of 2
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
      Ask FixBot
    4. HP 17-bs049dx USB Port Replacement: step 5, image 1 of 1
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
      Ask FixBot
    1. HP 17-bs049dx USB Port Replacement, USB Port: step 6, image 1 of 2 HP 17-bs049dx USB Port Replacement, USB Port: step 6, image 2 of 2
      • Remove the two screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. HP 17-bs049dx USB Port Replacement: step 7, image 1 of 3 HP 17-bs049dx USB Port Replacement: step 7, image 2 of 3 HP 17-bs049dx USB Port Replacement: step 7, image 3 of 3
      • At both ends of the connector ribbon, unclip both connectors.
      • Gently remove the ribbon from the unlatched area.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 54
All Time: 622
