HP 17-bs049dx Motherboard Replacement
    1. HP 17-bs049dx Motherboard Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
      Ask FixBot
    2. HP 17-bs049dx Motherboard Replacement: step 2, image 1 of 1
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
      Ask FixBot
    3. HP 17-bs049dx Motherboard Replacement: step 3, image 1 of 2 HP 17-bs049dx Motherboard Replacement: step 3, image 2 of 2
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
      Ask FixBot
    4. HP 17-bs049dx Motherboard Replacement: step 4, image 1 of 1
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
      Ask FixBot
    1. HP 17-bs049dx Motherboard Replacement, Hard Drive: step 5, image 1 of 1
      • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
      • Lift the USB port over and away from hard drive.
      Ask FixBot
    2. HP 17-bs049dx Motherboard Replacement: step 6, image 1 of 2 HP 17-bs049dx Motherboard Replacement: step 6, image 2 of 2
      • Lift rubber black tabs located on the hard drive upwards.
      • Disconnect hard drive from motherboard by pulling towards you.
      Ask FixBot
    1. HP 17-bs049dx Motherboard Replacement, Motherboard: step 7, image 1 of 3 HP 17-bs049dx Motherboard Replacement, Motherboard: step 7, image 2 of 3 HP 17-bs049dx Motherboard Replacement, Motherboard: step 7, image 3 of 3
      • Make sure to unplug everything connected to the motherboard.
      • Be gentle with this step.
      Ask FixBot
    2. HP 17-bs049dx Motherboard Replacement: step 8, image 1 of 1
      • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
      • Once all of the screws are removed, remove the motherboard from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 68
All Time: 1,305
