Up to 20% off select tools
HP 17-bs049dx Fan Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
65
All Time:
1,258
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the fan in your laptop.
    1. HP 17-bs049dx Fan Replacement, Battery: step 1, image 1 of 1
      • To remove the battery, simply push the tabs towards each other.
      • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
      Ask FixBot
    1. HP 17-bs049dx Fan Replacement, Back Panel: step 2, image 1 of 1
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
      Ask FixBot
    2. HP 17-bs049dx Fan Replacement: step 3, image 1 of 1
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
      Ask FixBot
    3. HP 17-bs049dx Fan Replacement: step 4, image 1 of 2 HP 17-bs049dx Fan Replacement: step 4, image 2 of 2
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
      Ask FixBot
    4. HP 17-bs049dx Fan Replacement: step 5, image 1 of 1
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
      Ask FixBot
    1. HP 17-bs049dx Fan Replacement, Fan: step 6, image 1 of 3 HP 17-bs049dx Fan Replacement, Fan: step 6, image 2 of 3 HP 17-bs049dx Fan Replacement, Fan: step 6, image 3 of 3
      • Unscrew all four screws connecting the heatsink to the motherboard.
      • The screws holding the heat sink will not detach from the heat sink.
      • All four screws must be loosened before removing the heat sink.
      • After loosening all screws remove the heat sink and store it in a safe place.
      Ask FixBot
    2. HP 17-bs049dx Fan Replacement: step 7, image 1 of 1
      • After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
      Ask FixBot
    3. HP 17-bs049dx Fan Replacement: step 8, image 1 of 1
      • Remove the old fan from the device.
      Ask FixBot
Author
with
Juan Seoane-Seri
183 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 65
All Time: 1,258
