Up to 20% off select tools
HP 17-bs049dx Back Panel Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
66
All Time:
2,161
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
During the process, be careful with the placement of removed screws. This back panel disassembly is required to access all internal components.
    1. HP 17-bs049dx Back Panel Replacement, Battery: step 1, image 1 of 1
      • To remove the battery, simply push the tabs towards each other.
      • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
      Ask FixBot
    1. HP 17-bs049dx Back Panel Replacement, Back Panel: step 2, image 1 of 1
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
      Ask FixBot
    2. HP 17-bs049dx Back Panel Replacement: step 3, image 1 of 1
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
      Ask FixBot
    3. HP 17-bs049dx Back Panel Replacement: step 4, image 1 of 2 HP 17-bs049dx Back Panel Replacement: step 4, image 2 of 2
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
      Ask FixBot
    4. HP 17-bs049dx Back Panel Replacement: step 5, image 1 of 1
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
      Ask FixBot
6 other people completed this guide.
Author
with
Megan Paige
475 Reputation
2 Guides authored
2 Guide Comments
In my experience an additional four bolts secure the bottom panel, each under the long rubber feet. Lift the outer ends of each foot to reveal the bolts. These must be removed to free the bottom panel - the bottom panel can't be removed sans damage until these four bolts, in addition to those noted in the guide above, are removed.
Bruce Campbell - Reply Share
Apologies, the bolts described in the guide include the four under the feet which I noted. I stupidly missed them... But perhaps the rhetoric in the relevant section could be revised to note that a total of eight bolts are removed in that step to clarify that two separate sets of four bolts must be removed. A small image of a lifted foot with the bolt head showing underneath could further clarify them.
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 66
All Time: 2,161
