HP 15-r137wm TouchSmart Front Panel Assembly Replacement
  1. HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 3 of 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
    Ask FixBot
  2. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: step 2, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
    Ask FixBot
  3. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: step 3, image 1 of 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
    Ask FixBot
  4. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: step 4, image 1 of 2 HP 15-r137wm TouchSmart Front Panel Assembly Replacement: step 4, image 2 of 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
    Ask FixBot
2 other people completed this guide.
Ross B Jacques
881 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 714
