HP 15-r137wm TouchSmart CD Drive Replacement
    1. HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: step 1, image 1 of 3 HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: step 1, image 2 of 3 HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: step 1, image 3 of 3
      • Make sure that the device is powered off and unplugged before removing components.
      • Remove all ten (10) 5.5 mm Phillips #0 screws.
      • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
      Ask FixBot
    2. HP 15-r137wm TouchSmart CD Drive Replacement: step 2, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Use a wide plastic opening tool to pry off the top casing.
      • Be cautious not to crack the casing near the keyboard as it is quite fragile.
      • Lift the cover off carefully as there are wires still attached to internal components.
      • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
      Ask FixBot
    3. HP 15-r137wm TouchSmart CD Drive Replacement: step 3, image 1 of 1
      • The connection for the track pad is still connected.
      • Move the keyboard slightly out of the way to locate the connection.
      • Disconnect the small wire protruding from the motherboard underneath the metal plate.
      Ask FixBot
    4. HP 15-r137wm TouchSmart CD Drive Replacement: step 4, image 1 of 2 HP 15-r137wm TouchSmart CD Drive Replacement: step 4, image 2 of 2
      • Locate the connection between the power button and the connecting cable.
      • Do not lift the front panel off to far as the cable is still attached.
      • Remove the cable from the motherboard carefully.
      Ask FixBot
    1. HP 15-r137wm TouchSmart CD Drive Replacement, Keyboard: step 5, image 1 of 2 HP 15-r137wm TouchSmart CD Drive Replacement, Keyboard: step 5, image 2 of 2
      • Disconnect the connection between the keyboard the the motherboard.
      Ask FixBot
    2. HP 15-r137wm TouchSmart CD Drive Replacement: step 6, image 1 of 2 HP 15-r137wm TouchSmart CD Drive Replacement: step 6, image 2 of 2
      • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
      • Lift the metal retaining plate off and away from the device.
      Ask FixBot
    1. HP 15-r137wm TouchSmart CD Drive Replacement, CD Drive: step 7, image 1 of 2 HP 15-r137wm TouchSmart CD Drive Replacement, CD Drive: step 7, image 2 of 2
      • Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
      Ask FixBot
Ross B Jacques
881 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 452
