HP 15-g071nr Hard Drive Replacement
    1. HP 15-g071nr Hard Drive Replacement, Battery: step 1, image 1 of 2 HP 15-g071nr Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over so the bottom is facing upwards.
      Ask FixBot
    2. HP 15-g071nr Hard Drive Replacement: step 2, image 1 of 2 HP 15-g071nr Hard Drive Replacement: step 2, image 2 of 2
      • Press the tabs at the corners of the laptop at the same time to release the battery.
      Ask FixBot
    3. HP 15-g071nr Hard Drive Replacement: step 3, image 1 of 3 HP 15-g071nr Hard Drive Replacement: step 3, image 2 of 3 HP 15-g071nr Hard Drive Replacement: step 3, image 3 of 3
      • Pull the battery away from the laptop in one motion.
      Ask FixBot
    1. HP 15-g071nr Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
      • Using your Phillips #0 screwdriver, remove all of the screws on the back case.
      Ask FixBot
    2. HP 15-g071nr Hard Drive Replacement: step 5, image 1 of 3 HP 15-g071nr Hard Drive Replacement: step 5, image 2 of 3 HP 15-g071nr Hard Drive Replacement: step 5, image 3 of 3
      • Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
      • Remove the wrist rest once it comes loose from the body.
      Ask FixBot
    3. HP 15-g071nr Hard Drive Replacement: step 6, image 1 of 3 HP 15-g071nr Hard Drive Replacement: step 6, image 2 of 3 HP 15-g071nr Hard Drive Replacement: step 6, image 3 of 3
      • Remove the two screws with the Phillips #0.
      • Gently pull the hard drive out of its SATA connection to the motherboard.
      • Attach the loose data cable to the new drive.
      • Be careful not to damage the silver ribbon cable below the hard drive itself.
      Ask FixBot
Emerson Tatelbaum
543 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,318
