HP 15-g071nr Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
56
All Time:
650
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your HP 15-g071nr laptop battery produces short use time, power issues, slow charge time, or even overheating, use this guide to safely and successfully replace the battery.
This three step guide is easy to follow and requires no tools to complete. Before following these steps, disconnect the device from any external power sources and power off the device completely.
    1. HP 15-g071nr Battery Replacement, Battery: step 1, image 1 of 2 HP 15-g071nr Battery Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over so the bottom is facing upwards.
      Ask FixBot
    2. HP 15-g071nr Battery Replacement: step 2, image 1 of 2 HP 15-g071nr Battery Replacement: step 2, image 2 of 2
      • Press the tabs at the corners of the laptop at the same time to release the battery.
      Ask FixBot
    3. HP 15-g071nr Battery Replacement: step 3, image 1 of 3 HP 15-g071nr Battery Replacement: step 3, image 2 of 3 HP 15-g071nr Battery Replacement: step 3, image 3 of 3
      • Pull the battery away from the laptop in one motion.
      Ask FixBot
2 other people completed this guide.
Emerson Tatelbaum
543 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 56
All Time: 650
