HP 15-g029wm RAM Replacement
    1. HP 15-g029wm RAM Replacement, Battery: step 1, image 1 of 1
      • Unplug any charging cord or accessories connected to the device before beginning.
      Ask FixBot
    2. HP 15-g029wm RAM Replacement: step 2, image 1 of 1
      • Place the laptop bottom-side up on a secure, flat surface.
      Ask FixBot
    3. HP 15-g029wm RAM Replacement: step 3, image 1 of 3 HP 15-g029wm RAM Replacement: step 3, image 2 of 3 HP 15-g029wm RAM Replacement: step 3, image 3 of 3
      • Slide each of the two switches that secure the battery to the left.
      • This will reveal an image of an unlocked lock.
      Ask FixBot
    4. HP 15-g029wm RAM Replacement: step 4, image 1 of 3 HP 15-g029wm RAM Replacement: step 4, image 2 of 3 HP 15-g029wm RAM Replacement: step 4, image 3 of 3
      • Use your hands to gently pull the disconnected battery out of the device.
      • When inserting the new battery, pay special attention to align the battery connections correctly.
      Ask FixBot
    1. HP 15-g029wm RAM Replacement, Upper Case: step 5, image 1 of 2 HP 15-g029wm RAM Replacement, Upper Case: step 5, image 2 of 2
      • Remove the following Phillips screws on the lower case:
      • Nine 5 mm
      • One 6 mm
      • This will allow the optical drive to separate from the chassis.
      Ask FixBot
    2. HP 15-g029wm RAM Replacement: step 6, image 1 of 1
      • Slide the optical drive directly out of its slot.
      Ask FixBot
    3. HP 15-g029wm RAM Replacement: step 7, image 1 of 1
      • Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
      Ask FixBot
    4. HP 15-g029wm RAM Replacement: step 8, image 1 of 3 HP 15-g029wm RAM Replacement: step 8, image 2 of 3 HP 15-g029wm RAM Replacement: step 8, image 3 of 3
      • Use an opening pick to remove the two circular rubber feet near the laptop hinges.
      • Remove both of the 8 mm Phillips screws.
      • The screws were hidden by the rubber feet.
      Ask FixBot
    5. HP 15-g029wm RAM Replacement: step 9, image 1 of 2 HP 15-g029wm RAM Replacement: step 9, image 2 of 2
      • Use an opening pick to pry up and remove the left hinge cover.
      • Use an opening pick to pry up and remove the right hinge cover.
      Ask FixBot
    6. HP 15-g029wm RAM Replacement: step 10, image 1 of 3 HP 15-g029wm RAM Replacement: step 10, image 2 of 3 HP 15-g029wm RAM Replacement: step 10, image 3 of 3
      • Flip the device face up and open the lid.
      • Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
      • Lift the keyboard slightly.
      • There is a ribbon cable connecting the keyboard to the device on the underside. Do NOT pull it away or you risk ripping the ribbon cable and causing damage.
      • Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
      • Disconnect the keyboard ribbon cable.
      • Lift the keyboard off.
      Ask FixBot
    7. HP 15-g029wm RAM Replacement: step 11, image 1 of 3 HP 15-g029wm RAM Replacement: step 11, image 2 of 3 HP 15-g029wm RAM Replacement: step 11, image 3 of 3
      • Remove two 5 mm screws using a Phillips screwdriver.
      • Insert an opening pick in the seam between the top case and chassis.
      • Slide the opening pick around the edge of the device to separate the top case from the chassis.
      • Slightly lift the top case up and away from the chassis.
      • There is a ribbon cable connecting the top plate to the device. Handle with care, and do NOT yank on the ribbon cable to prevent damage.
      Ask FixBot
    8. HP 15-g029wm RAM Replacement: step 12, image 1 of 3 HP 15-g029wm RAM Replacement: step 12, image 2 of 3 HP 15-g029wm RAM Replacement: step 12, image 3 of 3
      • Use your fingers or an opening pick to flip up the black ZIF locking flap.
      • Disconnect the ribbon cable.
      • Lift off the top case.
      Ask FixBot
    1. HP 15-g029wm RAM Replacement, Fan: step 13, image 1 of 2 HP 15-g029wm RAM Replacement, Fan: step 13, image 2 of 2
      • Use a Phillips screwdriver to remove the three 5 mm screws that secure the fan.
      Ask FixBot
    2. HP 15-g029wm RAM Replacement: step 14, image 1 of 2 HP 15-g029wm RAM Replacement: step 14, image 2 of 2
      • Gently "walk" the fan connector directly out of its motherboard socket.
      • Do not pull on the wires.
      Ask FixBot
    3. HP 15-g029wm RAM Replacement: step 15, image 1 of 1
      • Lift the fan up and out of the chassis.
      Ask FixBot
    1. HP 15-g029wm RAM Replacement, Motherboard: step 16, image 1 of 3 HP 15-g029wm RAM Replacement, Motherboard: step 16, image 2 of 3 HP 15-g029wm RAM Replacement, Motherboard: step 16, image 3 of 3
      • Use two opening picks to disconnect the display cable.
      Ask FixBot
    2. HP 15-g029wm RAM Replacement: step 17, image 1 of 1
      • Use an opening pick to gently "walk" the white speaker connector directly out of its port.
      Ask FixBot
    3. HP 15-g029wm RAM Replacement: step 18, image 1 of 3 HP 15-g029wm RAM Replacement: step 18, image 2 of 3 HP 15-g029wm RAM Replacement: step 18, image 3 of 3
      • Remove the four 3 mm screws that secure the motherboard.
      • Lift the front edge of the motherboard slightly.
      • There is a ribbon cable connecting the motherboard to the device chassis. Do not yank it away.
      Ask FixBot
    4. HP 15-g029wm RAM Replacement: step 19, image 1 of 3 HP 15-g029wm RAM Replacement: step 19, image 2 of 3 HP 15-g029wm RAM Replacement: step 19, image 3 of 3
      • Use an opening pick or your fingers to release the ZIF locking flap.
      • Pull the ribbon cable out of its port.
      Ask FixBot
    5. HP 15-g029wm RAM Replacement: step 20, image 1 of 1
      • The motherboard is now fully disconnected and able to be removed from the chassis by lifting it out with your hands.
      • Remove the following components for your new motherboard: Heatsink, RAM, CMOS battery.
      Ask FixBot
    1. HP 15-g029wm RAM Replacement, RAM: step 21, image 1 of 1
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module
      • When released, the RAM modules will pop up at a slight angle.
      • Slide the RAM module straight out of its socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 67
All Time: 511
