HP 15-g010dx Button Board Replacement
    1. HP 15-g010dx Button Board Replacement, Battery: step 1, image 1 of 1
      • Slide the latch towards the center of the laptop so the unlock emblem appears.
      Ask FixBot
    2. HP 15-g010dx Button Board Replacement: step 2, image 1 of 1
      • Place your finger on the left latch and slide it towards the center of the laptop.
      Ask FixBot
    3. HP 15-g010dx Button Board Replacement: step 3, image 1 of 1
      • Pull on the battery to remove.
      Ask FixBot
    1. HP 15-g010dx Button Board Replacement, Keyboard: step 4, image 1 of 1
      • Remove the two 5 mm screws with the Phillips #00 screwdriver.
      Ask FixBot
    2. HP 15-g010dx Button Board Replacement: step 5, image 1 of 1
      • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
      Ask FixBot
    3. HP 15-g010dx Button Board Replacement: step 6, image 1 of 1
      • Using the tool of your choice, gently pry up on the top of the keyboard.
      Ask FixBot
    4. HP 15-g010dx Button Board Replacement: step 7, image 1 of 1
      • Release the top of the keyboard.
      Ask FixBot
    5. HP 15-g010dx Button Board Replacement: step 8, image 1 of 1
      • Remove the ZIF connector that connects the laptop to the keyboard cable.
      Ask FixBot
    1. HP 15-g010dx Button Board Replacement, Button Board: step 9, image 1 of 1
      • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
      Ask FixBot
    2. HP 15-g010dx Button Board Replacement: step 10, image 1 of 1
      • Using the spudger, remove the two rubber feet that are located near the battery.
      Ask FixBot
    3. HP 15-g010dx Button Board Replacement: step 11, image 1 of 1
      • Now remove the two Phillips screws that are located below the rubber feet.
      Ask FixBot
    4. HP 15-g010dx Button Board Replacement: step 12, image 1 of 3 HP 15-g010dx Button Board Replacement: step 12, image 2 of 3 HP 15-g010dx Button Board Replacement: step 12, image 3 of 3
      • Remove the optical drive by pulling it out by hand.
      Ask FixBot
    5. HP 15-g010dx Button Board Replacement: step 13, image 1 of 1
      • Remove the two Phillips screws inside the optical drive housing.
      Ask FixBot
    6. HP 15-g010dx Button Board Replacement: step 14, image 1 of 1
      • Disconnect the power button ribbon cable by lifting the connector.
      Ask FixBot
    7. HP 15-g010dx Button Board Replacement: step 15, image 1 of 1
      • Now disconnect the touch pad ribbon cable by lifting the connector.
      Ask FixBot
    8. HP 15-g010dx Button Board Replacement: step 16, image 1 of 3 HP 15-g010dx Button Board Replacement: step 16, image 2 of 3 HP 15-g010dx Button Board Replacement: step 16, image 3 of 3
      • Remove the screws indicated by an arrow stamped into the metal.
      Ask FixBot
    9. HP 15-g010dx Button Board Replacement: step 17, image 1 of 1
      • Insert the spudger between the palmrest and the laptop body.
      Ask FixBot
    10. HP 15-g010dx Button Board Replacement: step 18, image 1 of 1
      • Lift up on palm rest, while working the spudger around the perimeter.
      Ask FixBot
    11. HP 15-g010dx Button Board Replacement: step 19, image 1 of 2 HP 15-g010dx Button Board Replacement: step 19, image 2 of 2
      • Remove palm rest and flip it over.
      Ask FixBot
    12. HP 15-g010dx Button Board Replacement: step 20, image 1 of 2 HP 15-g010dx Button Board Replacement: step 20, image 2 of 2
      • Release the cable connected to the button board.
      Ask FixBot
    13. HP 15-g010dx Button Board Replacement: step 21, image 1 of 2 HP 15-g010dx Button Board Replacement: step 21, image 2 of 2
      • Remove the two Phillips screws securing the button board.
      Ask FixBot
    14. HP 15-g010dx Button Board Replacement: step 22, image 1 of 1
      • Remove button board.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 67
All Time: 807
