HP 15-f162dx RAM Replacement
    1. HP 15-f162dx RAM Replacement, RAM: step 1, image 1 of 1
      • Be sure to power off and unplug your device before you begin the repair.
      Ask FixBot
    2. HP 15-f162dx RAM Replacement: step 2, image 1 of 1
      • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
      • Remove it at an angle and not straight up so you don't damage the socket.
      Ask FixBot
    3. HP 15-f162dx RAM Replacement: step 3, image 1 of 1
      • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
      • The RAM will pop up by a few millimeters.
      • Repeat steps in reverse order to reassemble the computer with new RAM
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 62
All Time: 884
