HP 15-f033wm Screen Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
94
All Time:
2,038
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
In the case that the screen on your laptop doesn’t show anything or the touch display is unresponsive, your laptop may have a faulty screen.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
    1. HP 15-f033wm Screen Replacement, Battery: step 1, image 1 of 1
      • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
      Ask FixBot
    2. HP 15-f033wm Screen Replacement: step 2, image 1 of 2 HP 15-f033wm Screen Replacement: step 2, image 2 of 2
      • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
      Ask FixBot
    3. HP 15-f033wm Screen Replacement: step 3, image 1 of 2 HP 15-f033wm Screen Replacement: step 3, image 2 of 2
      • Locate the battery and the two switches that release the battery when they are unlocked.
      Ask FixBot
    4. HP 15-f033wm Screen Replacement: step 4, image 1 of 2 HP 15-f033wm Screen Replacement: step 4, image 2 of 2
      • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
      Ask FixBot
    5. HP 15-f033wm Screen Replacement: step 5, image 1 of 3 HP 15-f033wm Screen Replacement: step 5, image 2 of 3 HP 15-f033wm Screen Replacement: step 5, image 3 of 3
      • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
      • While holding the switch in place, use your right hand to gently remove the battery from its port.
      Ask FixBot
    1. HP 15-f033wm Screen Replacement, Screen: step 6, image 1 of 1
      • After removing the battery, remove the bezel. Do this by prying it away from the faulty screen using the spudger.
      • Make sure screen is angles as far back as possible to fully remove the bottom hinges of the bezel without damaging the laptop.
      Ask FixBot
    2. HP 15-f033wm Screen Replacement: step 7, image 1 of 1
      • Remove the four 3 mm PH1 Phillips head screws in each corner of the screen, fastening the screen to the rest of the laptop.
      Ask FixBot
    3. HP 15-f033wm Screen Replacement: step 8, image 1 of 1
      • Gently remove the screen and place it on the keyboard.
      Ask FixBot
    4. HP 15-f033wm Screen Replacement: step 9, image 1 of 2 HP 15-f033wm Screen Replacement: step 9, image 2 of 2
      • Remove the tape on top of the video cable.
      • Gently disconnect the video cable.
      Ask FixBot
4 other people completed this guide.
Aaron Chabot
629 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 94
All Time: 2,038
