HP 15-f033wm CD Reader Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
91
All Time:
988
Comments: 11
11 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
In the case that your CD reader is not processing the information embedded on the discs, follow this repair guide on replacing your CD reader.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
    1. HP 15-f033wm CD Reader Replacement, Battery: step 1, image 1 of 1
      • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
      Ask FixBot
    2. HP 15-f033wm CD Reader Replacement: step 2, image 1 of 2 HP 15-f033wm CD Reader Replacement: step 2, image 2 of 2
      • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
      Ask FixBot
    3. HP 15-f033wm CD Reader Replacement: step 3, image 1 of 2 HP 15-f033wm CD Reader Replacement: step 3, image 2 of 2
      • Locate the battery and the two switches that release the battery when they are unlocked.
      Ask FixBot
    4. HP 15-f033wm CD Reader Replacement: step 4, image 1 of 2 HP 15-f033wm CD Reader Replacement: step 4, image 2 of 2
      • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
      Ask FixBot
    5. HP 15-f033wm CD Reader Replacement: step 5, image 1 of 3 HP 15-f033wm CD Reader Replacement: step 5, image 2 of 3 HP 15-f033wm CD Reader Replacement: step 5, image 3 of 3
      • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
      • While holding the switch in place, use your right hand to gently remove the battery from its port.
      Ask FixBot
    1. HP 15-f033wm CD Reader Replacement, Palm Rest Disassembly: step 6, image 1 of 1
      • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
      Ask FixBot
    2. HP 15-f033wm CD Reader Replacement: step 7, image 1 of 1
      • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
      Ask FixBot
    3. HP 15-f033wm CD Reader Replacement: step 8, image 1 of 1
      • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
      Ask FixBot
    4. HP 15-f033wm CD Reader Replacement: step 9, image 1 of 2 HP 15-f033wm CD Reader Replacement: step 9, image 2 of 2
      • Remove the palm rest using the blue spudger tool.
      Ask FixBot
    5. HP 15-f033wm CD Reader Replacement: step 10, image 1 of 1
      • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
      Ask FixBot
    6. HP 15-f033wm CD Reader Replacement: step 11, image 1 of 1
      • Remove metal keyboard underlayment.
      • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
      Ask FixBot
    1. HP 15-f033wm CD Reader Replacement, CD Reader: step 12, image 1 of 1
      • Remove metal bar on top of the CD drive. Do this by removing 3 mm PH1 Phillips head screw that is just below the bottom right corner of CD drive.
      Ask FixBot
    2. HP 15-f033wm CD Reader Replacement: step 13, image 1 of 1
      • Remove the 3 mm PH1 Phillips head screw that is just to the left of the CD drive.
      Ask FixBot
    3. HP 15-f033wm CD Reader Replacement: step 14, image 1 of 3 HP 15-f033wm CD Reader Replacement: step 14, image 2 of 3 HP 15-f033wm CD Reader Replacement: step 14, image 3 of 3
      • Carefully push the CD drive from its left side out of the laptop.
      Ask FixBot
Aaron Chabot
629 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 91
All Time: 988
