HP 15-f009wm RAM Replacement
    1. HP 15-f009wm RAM Replacement, Battery: step 1, image 1 of 2 HP 15-f009wm RAM Replacement, Battery: step 1, image 2 of 2
      • Turn laptop upside down.
      • Flip the lock switch to the unlocked setting.
      Ask FixBot
    2. HP 15-f009wm RAM Replacement: step 2, image 1 of 3 HP 15-f009wm RAM Replacement: step 2, image 2 of 3 HP 15-f009wm RAM Replacement: step 2, image 3 of 3
      • Flip the release switch.
      • Once the flip is switched, the battery should pop out.
      Ask FixBot
    3. HP 15-f009wm RAM Replacement: step 3, image 1 of 2 HP 15-f009wm RAM Replacement: step 3, image 2 of 2
      • Slide the battery out.
      Ask FixBot
    1. HP 15-f009wm RAM Replacement, RAM: step 4, image 1 of 3 HP 15-f009wm RAM Replacement, RAM: step 4, image 2 of 3 HP 15-f009wm RAM Replacement, RAM: step 4, image 3 of 3
      • Remove the two Phillips #1 screws from the RAM panel.
      Ask FixBot
    2. HP 15-f009wm RAM Replacement: step 5, image 1 of 3 HP 15-f009wm RAM Replacement: step 5, image 2 of 3 HP 15-f009wm RAM Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to pop the panel off.
      Ask FixBot
    3. HP 15-f009wm RAM Replacement: step 6, image 1 of 3 HP 15-f009wm RAM Replacement: step 6, image 2 of 3 HP 15-f009wm RAM Replacement: step 6, image 3 of 3
      • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      Ask FixBot
    4. HP 15-f009wm RAM Replacement: step 7, image 1 of 1
      • Remove the RAM chip from the laptop.
      Ask FixBot
Alex Birchler
1,024 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Nance Spring 2018 Member of USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 72
All Time: 1,247
