HP 15-f004dx RAM Replacement
    1. HP 15-f004dx RAM Replacement, RAM: step 1, image 1 of 1
      • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
      Ask FixBot
    2. HP 15-f004dx RAM Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
      Ask FixBot
    3. HP 15-f004dx RAM Replacement: step 3, image 1 of 3 HP 15-f004dx RAM Replacement: step 3, image 2 of 3 HP 15-f004dx RAM Replacement: step 3, image 3 of 3
      • Remove the RAM shield.
      • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
      Ask FixBot
    4. HP 15-f004dx RAM Replacement: step 4, image 1 of 2 HP 15-f004dx RAM Replacement: step 4, image 2 of 2
      • The RAM card should now pop up out of its slot. Remove the RAM.
      • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
      Ask FixBot
1 Guide Comment
Cuánto es el maximo de ram permitido para este modelo? Estoy pensando en ampliarlo a 8 o 16
Christian Gutierrez - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 66
All Time: 1,359
