HP 15-f004dx Keyboard Replacement
    1. HP 15-f004dx Keyboard  Replacement, Battery: step 1, image 1 of 1
      • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
      Ask FixBot
    2. HP 15-f004dx Keyboard  Replacement: step 2, image 1 of 2 HP 15-f004dx Keyboard  Replacement: step 2, image 2 of 2
      • Locate a switch in the upper left corner with a lock symbol next to it.
      • Slide the switch to the right until you see an unlocked symbol on the opposite side.
      Ask FixBot
    3. HP 15-f004dx Keyboard  Replacement: step 3, image 1 of 2 HP 15-f004dx Keyboard  Replacement: step 3, image 2 of 2
      • There is another switch on the opposite side of the computer with a battery symbol next to it.
      • Slide this switch to the left and the battery should detach from the computer.
      • To completely remove the battery, simply pull the battery away from the computer.
      Ask FixBot
    1. HP 15-f004dx Keyboard  Replacement, Keyboard: step 4, image 1 of 1
      • Use a plastic opening tool to delicately pry the keyboard from the laptop.
      • Run the opening tool along the top edge so a good portion is lifted from the laptop.
      Ask FixBot
    2. HP 15-f004dx Keyboard  Replacement: step 5, image 1 of 1
      • Once a large enough portion of the laptop is lifted up, use your hand to finish separating the keyboard from the laptop
      Ask FixBot
    3. HP 15-f004dx Keyboard  Replacement: step 6, image 1 of 1
      • Lift the laptop and expose the connector.
      • Lift the small black tab of the keyboard ZIF connector, and gently pull the ribbon cable free.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 62
All Time: 994
