HP 15-ef2025nr Trackpad Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
66
All Time:
684
Comments: 10
10 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the touchpad of your HP 15-ef2025nr laptop is not responding, it may be a good time to replace it. However, please see the troubleshooting guide prior to replacing the touchpad. The touchpad is what allows you to move the cursor on your laptop. Without an operating touchpad, it is much harder to use your laptop because you would need a separate mouse.
Before starting this guide make sure you remove the computer battery for safety reasons.
Tools
    1. HP 15-ef2025nr Trackpad Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down with the hinge facing you.
      Ask FixBot
    2. HP 15-ef2025nr Trackpad Replacement: step 2, image 1 of 2 HP 15-ef2025nr Trackpad Replacement: step 2, image 2 of 2
      • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
      Ask FixBot
    3. HP 15-ef2025nr Trackpad Replacement: step 3, image 1 of 2 HP 15-ef2025nr Trackpad Replacement: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
      Ask FixBot
    4. HP 15-ef2025nr Trackpad Replacement: step 4, image 1 of 2 HP 15-ef2025nr Trackpad Replacement: step 4, image 2 of 2
      • Flip the laptop over and open the lid.
      • Insert an opening tool into the seam between the edge of the lower case and the chassis.
      • Gently pry around the entire perimeter until the lower case separates from the chassis.
      • Close the lid and flip the laptop back over.
      • Remove the lower case.
      Ask FixBot
    5. HP 15-ef2025nr Trackpad Replacement: step 5, image 1 of 3 HP 15-ef2025nr Trackpad Replacement: step 5, image 2 of 3 HP 15-ef2025nr Trackpad Replacement: step 5, image 3 of 3
      • Remove the five 2 mm Phillips screws holding the battery down.
      • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
      • Gently lift the front edge of the battery up to disconnect the socket.
      • Lift the battery up and out.
      Ask FixBot
    1. HP 15-ef2025nr Trackpad Replacement, Trackpad: step 6, image 1 of 2 HP 15-ef2025nr Trackpad Replacement, Trackpad: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to flip up the ZIF connector locking flap.
      • Use tweezers to disconnect the ribbon cable from the back of the track pad.
      Ask FixBot
    2. HP 15-ef2025nr Trackpad Replacement: step 7, image 1 of 3 HP 15-ef2025nr Trackpad Replacement: step 7, image 2 of 3 HP 15-ef2025nr Trackpad Replacement: step 7, image 3 of 3
      • Remove the six 2 mm Phillips screws securing the trackpad.
      • Remove the retaining plate from the bottom of the track pad.
      • Remove the track pad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 66
All Time: 684
