Introduction
Go to step 1 ↓Your device wont turn on or when running a BIOS/UEFI memory test shows that your SSD is no longer functioning. The Solid State Drive (SSD) is the long storage memory device. When you install a program or save a document this is where that data is stored. Operating system boot files are also located here, and are what allow you to use your device. When the SSD is no longer working properly it should always be replaced.
Tools
Remove the single 1 mm screw securing the SSD.
Gently remove the SSD by pulling it directly out of its port.
