HP 15-ef2025nr RAM Replacement
    1. HP 15-ef2025nr RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down with the hinge facing you.
      Ask FixBot
    2. HP 15-ef2025nr RAM Replacement: step 2, image 1 of 2 HP 15-ef2025nr RAM Replacement: step 2, image 2 of 2
      • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
      Ask FixBot
    3. HP 15-ef2025nr RAM Replacement: step 3, image 1 of 2 HP 15-ef2025nr RAM Replacement: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
      Ask FixBot
    4. HP 15-ef2025nr RAM Replacement: step 4, image 1 of 2 HP 15-ef2025nr RAM Replacement: step 4, image 2 of 2
      • Flip the laptop over and open the lid.
      • Insert an opening tool into the seam between the edge of the lower case and the chassis.
      • Gently pry around the entire perimeter until the lower case separates from the chassis.
      • Close the lid and flip the laptop back over.
      • Remove the lower case.
      Ask FixBot
    5. HP 15-ef2025nr RAM Replacement: step 5, image 1 of 3 HP 15-ef2025nr RAM Replacement: step 5, image 2 of 3 HP 15-ef2025nr RAM Replacement: step 5, image 3 of 3
      • Remove the five 2 mm Phillips screws holding the battery down.
      • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
      • Gently lift the front edge of the battery up to disconnect the socket.
      • Lift the battery up and out.
      Ask FixBot
    1. HP 15-ef2025nr RAM Replacement, RAM: step 6, image 1 of 3 HP 15-ef2025nr RAM Replacement, RAM: step 6, image 2 of 3 HP 15-ef2025nr RAM Replacement, RAM: step 6, image 3 of 3
      • Gently pry apart the two silver retention arms simultaneously.
      • The RAM module will pop up at a 45 degree angle.
      • Pull the RAM module directly out its socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 69
All Time: 1,047
