HP 15-ef2025nr Fan Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
20
Past 30 Days:
81
All Time:
871
Comments: 11
11 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your HP 15-ef2025nr laptop is constantly overheating, it may be time to replace the fan inside. The fan is what pulls cool air into the computer to prevent the circuits from getting too hot. Having the circuits get too hot creates problems with the laptop. Check out the troubleshooting guide for more diagnosing information. For the device, we recommend an original quality replacement part for all repairs.
Before following this guide, please make sure your computer is not hot to the touch and the computer battery is removed.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP 15-ef2025nr Fan Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop upside down with the hinge facing you.
      Ask FixBot
    2. HP 15-ef2025nr Fan Replacement: step 2, image 1 of 2 HP 15-ef2025nr Fan Replacement: step 2, image 2 of 2
      • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
      Ask FixBot
    3. HP 15-ef2025nr Fan Replacement: step 3, image 1 of 2 HP 15-ef2025nr Fan Replacement: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
      Ask FixBot
    4. HP 15-ef2025nr Fan Replacement: step 4, image 1 of 2 HP 15-ef2025nr Fan Replacement: step 4, image 2 of 2
      • Flip the laptop over and open the lid.
      • Insert an opening tool into the seam between the edge of the lower case and the chassis.
      • Gently pry around the entire perimeter until the lower case separates from the chassis.
      • Close the lid and flip the laptop back over.
      • Remove the lower case.
      Ask FixBot
    5. HP 15-ef2025nr Fan Replacement: step 5, image 1 of 3 HP 15-ef2025nr Fan Replacement: step 5, image 2 of 3 HP 15-ef2025nr Fan Replacement: step 5, image 3 of 3
      • Remove the five 2 mm Phillips screws holding the battery down.
      • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
      • Gently lift the front edge of the battery up to disconnect the socket.
      • Lift the battery up and out.
      Ask FixBot
    1. HP 15-ef2025nr Fan Replacement, Fan: step 6, image 1 of 3 HP 15-ef2025nr Fan Replacement, Fan: step 6, image 2 of 3 HP 15-ef2025nr Fan Replacement, Fan: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to pull the fan connector directly out of its motherboard socket.
      • Do not pull on the wires; they are very delicate.
      Ask FixBot
    2. HP 15-ef2025nr Fan Replacement: step 7, image 1 of 3 HP 15-ef2025nr Fan Replacement: step 7, image 2 of 3 HP 15-ef2025nr Fan Replacement: step 7, image 3 of 3
      • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
      • Remove the fan.
      Ask FixBot
kyle mccomas
296 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 81
All Time: 871
