Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓This guide shows how to replace the battery in the HP 15-ef1041nr laptop (HP 15-ef series) to restore proper power and portability. The battery supplies power when unplugged and may need replacement if the laptop won’t charge, drains quickly, or shuts down unexpectedly—see troubling shooting guide for confirmation. Before starting, power off and unplug the device, use ESD-safe practices, and disconnect the battery early to prevent damage. If the battery is swollen, handle it carefully and dispose of it at a proper e-waste facility.
Parts
Tools
Use an opening tool to remove the two rubber feet on the lower case.
Place the rubber strips off to the side with the stickey side up.
Remove the five 2 mm x 3 mm screws that secures the battery.
Use an opening tool to carefully lift the battery up.
At a 45 degree angle, pull the battery away from the motherboard.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
