Up to 20% off select tools
HP 15-ef RAM Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
55
Past 30 Days:
210
All Time:
2,832
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade the RAM in your HP 15 Laptop PC.
Note: This procedure was written using a model 15-dy2702dx HP 15 Laptop PC, but is fully compatible with any HP 15 Laptop PC whose model number starts with 15-dy or 15-ef.
This laptop has two RAM slots that support DDR4 SO-DIMM memory modules.
    1. HP 15-ef RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP 15-ef RAM Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP 15-ef RAM Replacement, Peel up an end of the front foot: step 3, image 1 of 3 HP 15-ef RAM Replacement, Peel up an end of the front foot: step 3, image 2 of 3 HP 15-ef RAM Replacement, Peel up an end of the front foot: step 3, image 3 of 3
      • The rubber feet cover a total of six back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
      Ask FixBot
    3. HP 15-ef RAM Replacement, Remove the front foot: step 4, image 1 of 3 HP 15-ef RAM Replacement, Remove the front foot: step 4, image 2 of 3 HP 15-ef RAM Replacement, Remove the front foot: step 4, image 3 of 3
      • Peel the front foot away from the back cover and remove it.
      Ask FixBot
    4. HP 15-ef RAM Replacement, Remove the rear foot: step 5, image 1 of 3 HP 15-ef RAM Replacement, Remove the rear foot: step 5, image 2 of 3 HP 15-ef RAM Replacement, Remove the rear foot: step 5, image 3 of 3
      • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
      • Peel the rear foot away from the back cover and remove it.
      Ask FixBot
    5. HP 15-ef RAM Replacement, Reassembly information: step 6, image 1 of 3 HP 15-ef RAM Replacement, Reassembly information: step 6, image 2 of 3 HP 15-ef RAM Replacement, Reassembly information: step 6, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Note that the rubber feet are different:
      • The rear foot is thicker, with a deeper recess.
      • The front foot is thinner, with a shallower recess.
      • During reassembly:
      • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
      • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
      • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
      • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
      Ask FixBot
    1. HP 15-ef RAM Replacement, Unfasten the back cover: step 7, image 1 of 2 HP 15-ef RAM Replacement, Unfasten the back cover: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the eight screws securing the back cover:
      • Six 6.5 mm-long silver screws
      • Two 6.7 mm-long black screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    2. HP 15-ef RAM Replacement, Open your laptop: step 8, image 1 of 3 HP 15-ef RAM Replacement, Open your laptop: step 8, image 2 of 3 HP 15-ef RAM Replacement, Open your laptop: step 8, image 3 of 3
      • Flip your laptop over and open the screen.
      Ask FixBot
    3. HP 15-ef RAM Replacement, Release the clips: step 9, image 1 of 2 HP 15-ef RAM Replacement, Release the clips: step 9, image 2 of 2
      • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
      • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
      Ask FixBot
    4. HP 15-ef RAM Replacement: step 10, image 1 of 2 HP 15-ef RAM Replacement: step 10, image 2 of 2
      • Avoid using excessive force when prying near the SD card slot, as it's a weak point in the case.
      • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
      • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    5. HP 15-ef RAM Replacement: step 11, image 1 of 3 HP 15-ef RAM Replacement: step 11, image 2 of 3 HP 15-ef RAM Replacement: step 11, image 3 of 3
      • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
      • Slide the opening pick to the bottom left corner to release the remaining clips.
      Ask FixBot
    6. HP 15-ef RAM Replacement, Flip your laptop over: step 12, image 1 of 3 HP 15-ef RAM Replacement, Flip your laptop over: step 12, image 2 of 3 HP 15-ef RAM Replacement, Flip your laptop over: step 12, image 3 of 3
      • Close the screen and flip your laptop back over again.
      Ask FixBot
    7. HP 15-ef RAM Replacement, Remove the back cover: step 13, image 1 of 3 HP 15-ef RAM Replacement, Remove the back cover: step 13, image 2 of 3 HP 15-ef RAM Replacement, Remove the back cover: step 13, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
      Ask FixBot
    1. HP 15-ef RAM Replacement, Unfasten the battery: step 14, image 1 of 2 HP 15-ef RAM Replacement, Unfasten the battery: step 14, image 2 of 2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
      Ask FixBot
    2. HP 15-ef RAM Replacement, Remove the battery: step 15, image 1 of 3 HP 15-ef RAM Replacement, Remove the battery: step 15, image 2 of 3 HP 15-ef RAM Replacement, Remove the battery: step 15, image 3 of 3
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Remove the battery.
      • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
    1. HP 15-ef RAM Replacement, Unlatch the RAM: step 16, image 1 of 3 HP 15-ef RAM Replacement, Unlatch the RAM: step 16, image 2 of 3 HP 15-ef RAM Replacement, Unlatch the RAM: step 16, image 3 of 3
      • Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
      • Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
      Ask FixBot
    2. HP 15-ef RAM Replacement, Remove the RAM: step 17, image 1 of 2 HP 15-ef RAM Replacement, Remove the RAM: step 17, image 2 of 2
      • Pull the stick of RAM out of its socket to remove it.
      • Repeat for a second stick of RAM.
      • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
      Ask FixBot
4 other people completed this guide.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 55
Past 30 Days: 210
All Time: 2,832
