Up to 20% off select tools
HP 15-ef Battery Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
211
All Time:
4,763
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your HP 15 Laptop PC.
Note: This procedure was written using a model 15-dy2702dx HP 15 Laptop PC, but is fully compatible with any HP 15 Laptop PC whose model number starts with 15-dy or 15-ef.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    1. HP 15-ef Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP 15-ef Battery Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP 15-ef Battery Replacement, Peel up an end of the front foot: step 3, image 1 of 3 HP 15-ef Battery Replacement, Peel up an end of the front foot: step 3, image 2 of 3 HP 15-ef Battery Replacement, Peel up an end of the front foot: step 3, image 3 of 3
      • The rubber feet cover a total of six back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
      Ask FixBot
    3. HP 15-ef Battery Replacement, Remove the front foot: step 4, image 1 of 3 HP 15-ef Battery Replacement, Remove the front foot: step 4, image 2 of 3 HP 15-ef Battery Replacement, Remove the front foot: step 4, image 3 of 3
      • Peel the front foot away from the back cover and remove it.
      Ask FixBot
    4. HP 15-ef Battery Replacement, Remove the rear foot: step 5, image 1 of 3 HP 15-ef Battery Replacement, Remove the rear foot: step 5, image 2 of 3 HP 15-ef Battery Replacement, Remove the rear foot: step 5, image 3 of 3
      • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
      • Peel the rear foot away from the back cover and remove it.
      Ask FixBot
    5. HP 15-ef Battery Replacement, Reassembly information: step 6, image 1 of 3 HP 15-ef Battery Replacement, Reassembly information: step 6, image 2 of 3 HP 15-ef Battery Replacement, Reassembly information: step 6, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Note that the rubber feet are different:
      • The rear foot is thicker, with a deeper recess.
      • The front foot is thinner, with a shallower recess.
      • During reassembly:
      • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
      • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
      • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
      • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
      Ask FixBot
    1. HP 15-ef Battery Replacement, Unfasten the back cover: step 7, image 1 of 2 HP 15-ef Battery Replacement, Unfasten the back cover: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the eight screws securing the back cover:
      • Six 6.5 mm-long silver screws
      • Two 6.7 mm-long black screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    2. HP 15-ef Battery Replacement, Open your laptop: step 8, image 1 of 3 HP 15-ef Battery Replacement, Open your laptop: step 8, image 2 of 3 HP 15-ef Battery Replacement, Open your laptop: step 8, image 3 of 3
      • Flip your laptop over and open the screen.
      Ask FixBot
    3. HP 15-ef Battery Replacement, Release the clips: step 9, image 1 of 2 HP 15-ef Battery Replacement, Release the clips: step 9, image 2 of 2
      • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
      • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
      Ask FixBot
    4. HP 15-ef Battery Replacement: step 10, image 1 of 2 HP 15-ef Battery Replacement: step 10, image 2 of 2
      • Avoid using excessive force when prying near the SD card slot, as it's a weak point in the case.
      • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
      • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    5. HP 15-ef Battery Replacement: step 11, image 1 of 3 HP 15-ef Battery Replacement: step 11, image 2 of 3 HP 15-ef Battery Replacement: step 11, image 3 of 3
      • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
      • Slide the opening pick to the bottom left corner to release the remaining clips.
      Ask FixBot
    6. HP 15-ef Battery Replacement, Flip your laptop over: step 12, image 1 of 3 HP 15-ef Battery Replacement, Flip your laptop over: step 12, image 2 of 3 HP 15-ef Battery Replacement, Flip your laptop over: step 12, image 3 of 3
      • Close the screen and flip your laptop back over again.
      Ask FixBot
    7. HP 15-ef Battery Replacement, Remove the back cover: step 13, image 1 of 3 HP 15-ef Battery Replacement, Remove the back cover: step 13, image 2 of 3 HP 15-ef Battery Replacement, Remove the back cover: step 13, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
      Ask FixBot
    1. HP 15-ef Battery Replacement, Unfasten the battery: step 14, image 1 of 2 HP 15-ef Battery Replacement, Unfasten the battery: step 14, image 2 of 2
      • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
      • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
      • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
      Ask FixBot
    2. HP 15-ef Battery Replacement, Remove the battery: step 15, image 1 of 3 HP 15-ef Battery Replacement, Remove the battery: step 15, image 2 of 3 HP 15-ef Battery Replacement, Remove the battery: step 15, image 3 of 3
      • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
      • Remove the battery.
      • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Author
with
Spencer Day
210,904 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 211
All Time: 4,763
