HP 15-dy2702dx Trackpad Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
86
All Time:
582
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide that explains how to replace the trackpad for the HP 15-dy2072dx. The trackpad may need replacement in case it stops working, cracks, or wears out.
The trackpad is responsible for allowing users to move their pointer and click on items without the need for a external mouse. Trackpads are usually found on laptop to aid with portability.
Tools
    1. HP 15-dy2702dx Trackpad Replacement, Lower Case: step 1, image 1 of 1
      • Remove both of the rubber strips to uncover the hidden screws.
      • You can use a prying tool to help lift an end.
      Ask FixBot
    2. HP 15-dy2702dx Trackpad Replacement: step 2, image 1 of 1
      • Unscrew all 8 Phillips #1 screws on the bottom panel:
      • Two M2.5x6
      • Six M2x6
      Ask FixBot
    3. HP 15-dy2702dx Trackpad Replacement: step 3, image 1 of 2 HP 15-dy2702dx Trackpad Replacement: step 3, image 2 of 2
      • Flip the laptop over and open the lid.
      • Separate the bottom panel from the main body by using the iFixit opening tool.
      • Ensure that the bottom panel is completely separated along the edges.
      Ask FixBot
    4. HP 15-dy2702dx Trackpad Replacement: step 4, image 1 of 2 HP 15-dy2702dx Trackpad Replacement: step 4, image 2 of 2
      • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
      • Close the laptop to allow the back edges to fully separate
      Ask FixBot
    5. HP 15-dy2702dx Trackpad Replacement: step 5, image 1 of 3 HP 15-dy2702dx Trackpad Replacement: step 5, image 2 of 3 HP 15-dy2702dx Trackpad Replacement: step 5, image 3 of 3
      • Flip the laptop over and carefully remove the lower case.
      Ask FixBot
    1. HP 15-dy2702dx Trackpad Replacement, Battery: step 6, image 1 of 2 HP 15-dy2702dx Trackpad Replacement, Battery: step 6, image 2 of 2
      • Remove the five M2x6 screws that secure the battery with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP 15-dy2702dx Trackpad Replacement: step 7, image 1 of 3 HP 15-dy2702dx Trackpad Replacement: step 7, image 2 of 3 HP 15-dy2702dx Trackpad Replacement: step 7, image 3 of 3
      • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
      • Lift the battery up and out.
      Ask FixBot
    1. HP 15-dy2702dx Trackpad Replacement, Trackpad: step 8, image 1 of 1
      • Find the trackpad.
      Ask FixBot
    2. HP 15-dy2702dx Trackpad Replacement: step 9, image 1 of 3 HP 15-dy2702dx Trackpad Replacement: step 9, image 2 of 3 HP 15-dy2702dx Trackpad Replacement: step 9, image 3 of 3
      • Unscrew the two M2x6 Phillips #1 screws securing the trackpad.
      Ask FixBot
    3. HP 15-dy2702dx Trackpad Replacement: step 10, image 1 of 2 HP 15-dy2702dx Trackpad Replacement: step 10, image 2 of 2
      • Remove the metal bracket.
      Ask FixBot
    4. HP 15-dy2702dx Trackpad Replacement: step 11, image 1 of 3 HP 15-dy2702dx Trackpad Replacement: step 11, image 2 of 3 HP 15-dy2702dx Trackpad Replacement: step 11, image 3 of 3
      • Lift the black ribbon covering the screws.
      • Unscrew the top three M2x3 Phillips #0 screws.
      Ask FixBot
    5. HP 15-dy2702dx Trackpad Replacement: step 12, image 1 of 3 HP 15-dy2702dx Trackpad Replacement: step 12, image 2 of 3 HP 15-dy2702dx Trackpad Replacement: step 12, image 3 of 3
      • Flip up the locking flap holding the trackpad ribbon in place.
      • Pull the ribbon straight out of its socket.
      Ask FixBot
    6. HP 15-dy2702dx Trackpad Replacement: step 13, image 1 of 2 HP 15-dy2702dx Trackpad Replacement: step 13, image 2 of 2
      • Peel back the sticky black strip holding the trackpad in place.
      Ask FixBot
    7. HP 15-dy2702dx Trackpad Replacement: step 14, image 1 of 2 HP 15-dy2702dx Trackpad Replacement: step 14, image 2 of 2
      • Remove the trackpad from the laptop.
      Ask FixBot
Zander Herbold
703 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2023 Member of Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 86
All Time: 582
