HP 15-dy2702dx SSD Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
138
All Time:
1,584
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide explains how to replace the storage drive on the HP 15-dy2072dx. The storage drive on this laptop is a solid state drive(SSD). A replacement may be necessary in case of drive failures or a need to upgrade to a greater storage space.
The storage drive is responsible for storing all your files, boot files, and the OS files. A replacement may be an exact part replacement or a upgrade to the amount of storage(i.e. 256 GB to 1 TB).
Caution to use ESD safe tools and ESD wrist strap as static discharge may damage the new drive or the motherboard.
Tools
    1. HP 15-dy2702dx SSD Replacement, Lower Case: step 1, image 1 of 1
      • Remove both of the rubber strips to uncover the hidden screws.
      • You can use a prying tool to help lift an end.
      Ask FixBot
    2. HP 15-dy2702dx SSD Replacement: step 2, image 1 of 1
      • Unscrew all 8 Phillips #1 screws on the bottom panel:
      • Two M2.5x6
      • Six M2x6
      Ask FixBot
    3. HP 15-dy2702dx SSD Replacement: step 3, image 1 of 2 HP 15-dy2702dx SSD Replacement: step 3, image 2 of 2
      • Flip the laptop over and open the lid.
      • Separate the bottom panel from the main body by using the iFixit opening tool.
      • Ensure that the bottom panel is completely separated along the edges.
      Ask FixBot
    4. HP 15-dy2702dx SSD Replacement: step 4, image 1 of 2 HP 15-dy2702dx SSD Replacement: step 4, image 2 of 2
      • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
      • Close the laptop to allow the back edges to fully separate
      Ask FixBot
    5. HP 15-dy2702dx SSD Replacement: step 5, image 1 of 3 HP 15-dy2702dx SSD Replacement: step 5, image 2 of 3 HP 15-dy2702dx SSD Replacement: step 5, image 3 of 3
      • Flip the laptop over and carefully remove the lower case.
      Ask FixBot
    1. HP 15-dy2702dx SSD Replacement, SSD: step 6, image 1 of 3 HP 15-dy2702dx SSD Replacement, SSD: step 6, image 2 of 3 HP 15-dy2702dx SSD Replacement, SSD: step 6, image 3 of 3
      • Locate the storage drive.
      • Unscrew the single screw holding the drive in place.
      • The screw is a M2x3 mm Phillips #1 head screw.
      Ask FixBot
    2. HP 15-dy2702dx SSD Replacement: step 7, image 1 of 3 HP 15-dy2702dx SSD Replacement: step 7, image 2 of 3 HP 15-dy2702dx SSD Replacement: step 7, image 3 of 3
      • Grab the drive by its side and gently pull it out.
      Ask FixBot
Zander Herbold
703 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2023 Member of Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 138
All Time: 1,584
