HP 15-dy2702dx Fan Replacement
    1. HP 15-dy2702dx Fan Replacement, Lower Case: step 1, image 1 of 1
      • Remove both of the rubber strips to uncover the hidden screws.
      • You can use a prying tool to help lift an end.
      Ask FixBot
    2. HP 15-dy2702dx Fan Replacement: step 2, image 1 of 1
      • Unscrew all 8 Phillips #1 screws on the bottom panel:
      • Two M2.5x6
      • Six M2x6
      Ask FixBot
    3. HP 15-dy2702dx Fan Replacement: step 3, image 1 of 2 HP 15-dy2702dx Fan Replacement: step 3, image 2 of 2
      • Flip the laptop over and open the lid.
      • Separate the bottom panel from the main body by using the iFixit opening tool.
      • Ensure that the bottom panel is completely separated along the edges.
      Ask FixBot
    4. HP 15-dy2702dx Fan Replacement: step 4, image 1 of 2 HP 15-dy2702dx Fan Replacement: step 4, image 2 of 2
      • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
      • Close the laptop to allow the back edges to fully separate
      Ask FixBot
    5. HP 15-dy2702dx Fan Replacement: step 5, image 1 of 3 HP 15-dy2702dx Fan Replacement: step 5, image 2 of 3 HP 15-dy2702dx Fan Replacement: step 5, image 3 of 3
      • Flip the laptop over and carefully remove the lower case.
      Ask FixBot
    1. HP 15-dy2702dx Fan Replacement, Fan: step 6, image 1 of 3 HP 15-dy2702dx Fan Replacement, Fan: step 6, image 2 of 3 HP 15-dy2702dx Fan Replacement, Fan: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew the three screws that secure the fan.
      • These screws sizes are M2x6.
      Ask FixBot
    2. HP 15-dy2702dx Fan Replacement: step 7, image 1 of 1
      • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
      • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
      Ask FixBot
    3. HP 15-dy2702dx Fan Replacement: step 8, image 1 of 2 HP 15-dy2702dx Fan Replacement: step 8, image 2 of 2
      • Gently lift the fan to remove it from the case.
      Ask FixBot
September Oo
439 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2023 Member of Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 77
All Time: 894
