HP 15-dy2024nr Trackpad Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
71
All Time:
647
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to replace the trackpad on the HP 15-dy2024nr. A trackpad detects the motion and position of a user's fingers, and translates them to a position on the screen.
To indicate whether your trackpad needs replacing, it will show signs of:
  • Touch not being registered.
  • Unable to click.
  • Lag.
  • Dents and/or scratches.
  • If liquid is spilled on it.
  • Heating up.
Tools
    1. HP 15-dy2024nr Trackpad Replacement, Back Cover: step 1, image 1 of 2 HP 15-dy2024nr Trackpad Replacement, Back Cover: step 1, image 2 of 2
      • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
      • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
      • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
      Ask FixBot
    2. HP 15-dy2024nr Trackpad Replacement: step 2, image 1 of 3 HP 15-dy2024nr Trackpad Replacement: step 2, image 2 of 3 HP 15-dy2024nr Trackpad Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove:
      • Two 2.5mm x 6mm screws
      • Six 2mm x 6mm screws
      • Be sure to keep different screw sizes separated.
      Ask FixBot
    3. HP 15-dy2024nr Trackpad Replacement: step 3, image 1 of 3 HP 15-dy2024nr Trackpad Replacement: step 3, image 2 of 3 HP 15-dy2024nr Trackpad Replacement: step 3, image 3 of 3
      • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
      • Using another iFixit opening tool, slide along the seam to unhook the clips.
      • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
      • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
      • After the clips have been released, flip the laptop over and lift the cover.
      Ask FixBot
    1. HP 15-dy2024nr Trackpad Replacement, Battery: step 4, image 1 of 3 HP 15-dy2024nr Trackpad Replacement, Battery: step 4, image 2 of 3 HP 15-dy2024nr Trackpad Replacement, Battery: step 4, image 3 of 3
      • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
      • Use the iFixit opening picks to lift the battery away from the laptop.
      Ask FixBot
    2. HP 15-dy2024nr Trackpad Replacement: step 5, image 1 of 3 HP 15-dy2024nr Trackpad Replacement: step 5, image 2 of 3 HP 15-dy2024nr Trackpad Replacement: step 5, image 3 of 3
      • Be aware that the battery is plugged into the motherboard.
      • Unplug the battery from the motherboard.
      • Lift the battery away from the laptop and remove.
      Ask FixBot
    1. HP 15-dy2024nr Trackpad Replacement, Trackpad: step 6, image 1 of 2 HP 15-dy2024nr Trackpad Replacement, Trackpad: step 6, image 2 of 2
      • Remove two 3.0 mm screws using a Phillips #1 screwdriver.
      • Lift the metal bracket away from the laptop and remove it with your hands.
      Ask FixBot
    2. HP 15-dy2024nr Trackpad Replacement: step 7, image 1 of 1
      • Remove three 2.0 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. HP 15-dy2024nr Trackpad Replacement: step 8, image 1 of 1
      • Lift the track pad away from the laptop and remove with your hands.
      Ask FixBot
Eylandra
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 71
All Time: 647
