HP 15-dy2024nr Fan Assembly Replacement
    1. HP 15-dy2024nr Fan Assembly Replacement, Back Cover: step 1, image 1 of 2 HP 15-dy2024nr Fan Assembly Replacement, Back Cover: step 1, image 2 of 2
      • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
      • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
      • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
      Ask FixBot
    2. HP 15-dy2024nr Fan Assembly Replacement: step 2, image 1 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 2, image 2 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove:
      • Two 2.5mm x 6mm screws
      • Six 2mm x 6mm screws
      • Be sure to keep different screw sizes separated.
      Ask FixBot
    3. HP 15-dy2024nr Fan Assembly Replacement: step 3, image 1 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 3, image 2 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 3, image 3 of 3
      • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
      • Using another iFixit opening tool, slide along the seam to unhook the clips.
      • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
      • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
      • After the clips have been released, flip the laptop over and lift the cover.
      Ask FixBot
    1. HP 15-dy2024nr Fan Assembly Replacement, Battery: step 4, image 1 of 3 HP 15-dy2024nr Fan Assembly Replacement, Battery: step 4, image 2 of 3 HP 15-dy2024nr Fan Assembly Replacement, Battery: step 4, image 3 of 3
      • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
      • Use the iFixit opening picks to lift the battery away from the laptop.
      Ask FixBot
    2. HP 15-dy2024nr Fan Assembly Replacement: step 5, image 1 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 5, image 2 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 5, image 3 of 3
      • Be aware that the battery is plugged into the motherboard.
      • Unplug the battery from the motherboard.
      • Lift the battery away from the laptop and remove.
      Ask FixBot
    1. HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: step 6, image 1 of 2 HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • If your fan needs to be cleaned, do that now. If it is not working properly, continue with these steps to remove the broken fan.
      • Use the nylon tipped reverse tweezers to lift the cables up from off the motherboard before attempting to disconnect the connector from the motherboard.
      • Do not use the tweezers to pull the cables off the motherboard.
      Ask FixBot
    2. HP 15-dy2024nr Fan Assembly Replacement: step 7, image 1 of 2 HP 15-dy2024nr Fan Assembly Replacement: step 7, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Wedge the Halberd spudger between the black plastic connector and the motherboard.
      • Lightly twist the spudger blade up. The connector should pop off.
      Ask FixBot
    3. HP 15-dy2024nr Fan Assembly Replacement: step 8, image 1 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 8, image 2 of 3 HP 15-dy2024nr Fan Assembly Replacement: step 8, image 3 of 3
      • Remove the three chrome-plated 2.0mm x 3.0mm screws holding the fan assembly in place using a Phillips #0 screwdriver.
      • Lift the fan assembly out of the laptop.
      Ask FixBot
2 other people completed this guide.
Nathaniel Reeves
393 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 42
All Time: 921
