HP 15-dy2024nr Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
85
All Time:
2,216
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your HP 15-dy2024nr is not charging or not holding a charge, you may need to replace the battery. This guide will help you remove the old battery. To do this you'll first need to remove the back cover.
If the battery is swollen take extra precautions to safely remove and dispose of it. As with all parts, be sure the laptop is powered off before removing the battery.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP 15-dy2024nr Battery Replacement, Back Cover: step 1, image 1 of 2 HP 15-dy2024nr Battery Replacement, Back Cover: step 1, image 2 of 2
      • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
      • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
      • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
      Ask FixBot
    2. HP 15-dy2024nr Battery Replacement: step 2, image 1 of 3 HP 15-dy2024nr Battery Replacement: step 2, image 2 of 3 HP 15-dy2024nr Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove:
      • Two 2.5mm x 6mm screws
      • Six 2mm x 6mm screws
      • Be sure to keep different screw sizes separated.
      Ask FixBot
    3. HP 15-dy2024nr Battery Replacement: step 3, image 1 of 3 HP 15-dy2024nr Battery Replacement: step 3, image 2 of 3 HP 15-dy2024nr Battery Replacement: step 3, image 3 of 3
      • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
      • Using another iFixit opening tool, slide along the seam to unhook the clips.
      • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
      • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
      • After the clips have been released, flip the laptop over and lift the cover.
      Ask FixBot
    1. HP 15-dy2024nr Battery Replacement, Battery: step 4, image 1 of 3 HP 15-dy2024nr Battery Replacement, Battery: step 4, image 2 of 3 HP 15-dy2024nr Battery Replacement, Battery: step 4, image 3 of 3
      • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
      • Use the iFixit opening picks to lift the battery away from the laptop.
      Ask FixBot
    2. HP 15-dy2024nr Battery Replacement: step 5, image 1 of 3 HP 15-dy2024nr Battery Replacement: step 5, image 2 of 3 HP 15-dy2024nr Battery Replacement: step 5, image 3 of 3
      • Be aware that the battery is plugged into the motherboard.
      • Unplug the battery from the motherboard.
      • Lift the battery away from the laptop and remove.
      Ask FixBot
2 other people completed this guide.
Konnor Young
595 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 85
All Time: 2,216
