HP 15-dw2065st Fan Replacement
    1. HP 15-dw2065st Fan Replacement, Fan: step 1, image 1 of 2 HP 15-dw2065st Fan Replacement, Fan: step 1, image 2 of 2
      • Press the top left button to turn the laptop off.
      • Make sure the laptop is unplugged.
      • The light on the left side of the base of the laptop indicates if the laptop is on or off.
      Ask FixBot
    2. HP 15-dw2065st Fan Replacement: step 2, image 1 of 3 HP 15-dw2065st Fan Replacement: step 2, image 2 of 3 HP 15-dw2065st Fan Replacement: step 2, image 3 of 3
      • Close the screen and flip the laptop over so the backside is facing up.
      • Using a Phillips screwdriver, remove the left and right corner screws.
      Ask FixBot
    3. HP 15-dw2065st Fan Replacement: step 3, image 1 of 3 HP 15-dw2065st Fan Replacement: step 3, image 2 of 3 HP 15-dw2065st Fan Replacement: step 3, image 3 of 3
      • Use a spudger or your fingers to remove the protective padding from the top and bottom of the base and expose the screws.
      • With a Phillips screwdriver, remove the five screws from the base.
      Ask FixBot
    4. HP 15-dw2065st Fan Replacement: step 4, image 1 of 3 HP 15-dw2065st Fan Replacement: step 4, image 2 of 3 HP 15-dw2065st Fan Replacement: step 4, image 3 of 3
      • Open the screen.
      • Use a spudger to pry the palm rest assembly from the laptop.
      • Work the spudger around the perimeter to release the clips that secure the palm rest assembly.
      • Remove the palm rest assembly carefully as there are ribbon cables attached on the other side.
      Ask FixBot
    5. HP 15-dw2065st Fan Replacement: step 5, image 1 of 2 HP 15-dw2065st Fan Replacement: step 5, image 2 of 2
      • With a Phillips screwdriver, remove the four screws securing the battery.
      • Remove the battery from the connector.
      Ask FixBot
    6. HP 15-dw2065st Fan Replacement: step 6, image 1 of 1
      • Use a spudger to lift the black locking flap.
      • Remove the ribbon cable.
      Ask FixBot
    7. HP 15-dw2065st Fan Replacement: step 7, image 1 of 3 HP 15-dw2065st Fan Replacement: step 7, image 2 of 3 HP 15-dw2065st Fan Replacement: step 7, image 3 of 3
      • Remove the black screw from the fan.
      • Pull the cable away from the connector in the same direction that the individual wires are running
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      • Remove the fan.
      Ask FixBot
    8. HP 15-dw2065st Fan Replacement: step 8, image 1 of 2 HP 15-dw2065st Fan Replacement: step 8, image 2 of 2
      • Set the new fan in place.
      • Plug in the new fan.
      • Screw in the new fan.
      • Return all parts to the base.
      • Close the base.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 86
All Time: 836
