Introduction
If your HP 15-dw0037wm laptop produces distorted or no sound, one or both internal speakers may have failed and needs to be replaced. The internal speakers are responsible for all audio output, and over time they can wear out or become damaged by dust, impact, and moisture. This guide will help walk you through safely removing the fault speakers and installing new ones to restore clear audio performance.
Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
Set the laptop down with the lower case facing up.
Lift a corner of the lower silicone foot and peel it completely off.
Repeat for the upper silicone foot.
Use a Phillips screwdriver to remove the the four 4 mm screws that secure the battery.
Use your fingernail or a spudger to gently lift the black ZIF locking flap that secures the ribbon cable.
Repeat the previous bullet on the other end of the ribbon cable.
Use a Phillips screwdriver to remove the four screws that secure the heatsink to the CPU and motherboard, then carefully remove the heatsink.
Use an opening tool to pry up and disconnect the two wireless card coaxial connectors.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
