Up to 20% off select tools
HP 15-dw0037wm RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
67
All Time:
696
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your HP 15-dw0037wm is freezing or experiencing performance issues, it could be due to faulty or insufficient RAM, which may need replacement. RAM (Random Access Memory) temporarily stores data your computer needs to access quickly over time, defective or outdated RAM can cause instability. Before replacing the RAM, always ensure your device is powered down before starting the replacement process.
    1. HP 15-dw0037wm RAM Replacement, Lower Case: step 1, image 1 of 2 HP 15-dw0037wm RAM Replacement, Lower Case: step 1, image 2 of 2
      • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Set the laptop down with the lower case facing up.
      • Lift a corner of the lower silicone foot and peel it completely off.
      • Repeat for the upper silicone foot.
      Ask FixBot
    2. HP 15-dw0037wm RAM Replacement: step 2, image 1 of 2 HP 15-dw0037wm RAM Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the five 8 mm screws.
      • Remove the two 5 mm Phillips screws.
      Ask FixBot
    3. HP 15-dw0037wm RAM Replacement: step 3, image 1 of 3 HP 15-dw0037wm RAM Replacement: step 3, image 2 of 3 HP 15-dw0037wm RAM Replacement: step 3, image 3 of 3
      • Insert an opening pick into the gap between the lower case and chassis.
      • Starting from a corner is recommended.
      • Slide the pick around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 15-dw0037wm RAM Replacement, RAM: step 4, image 1 of 3 HP 15-dw0037wm RAM Replacement, RAM: step 4, image 2 of 3 HP 15-dw0037wm RAM Replacement, RAM: step 4, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      Ask FixBot
    2. HP 15-dw0037wm RAM Replacement: step 5, image 1 of 3 HP 15-dw0037wm RAM Replacement: step 5, image 2 of 3 HP 15-dw0037wm RAM Replacement: step 5, image 3 of 3
      • Grab the RAM by the exposed side and gently remove it.
      Ask FixBot
Author
with
Emily Davila
654 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 67
All Time: 696
