HP 15-dw0037wm Lower Case Replacement
    1. HP 15-dw0037wm Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP 15-dw0037wm Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Set the laptop down with the lower case facing up.
      • Lift a corner of the lower silicone foot and peel it completely off.
      • Repeat for the upper silicone foot.
      Ask FixBot
    2. HP 15-dw0037wm Lower Case Replacement: step 2, image 1 of 2 HP 15-dw0037wm Lower Case Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the five 8 mm screws.
      • Remove the two 5 mm Phillips screws.
      Ask FixBot
    3. HP 15-dw0037wm Lower Case Replacement: step 3, image 1 of 3 HP 15-dw0037wm Lower Case Replacement: step 3, image 2 of 3 HP 15-dw0037wm Lower Case Replacement: step 3, image 3 of 3
      • Insert an opening pick into the gap between the lower case and chassis.
      • Starting from a corner is recommended.
      • Slide the pick around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
25,358 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,341 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 23
All Time: 211
