HP 15-dw0037wm Hard Drive Replacement
    1. HP 15-dw0037wm Hard Drive Replacement, Lower Case: step 1, image 1 of 2 HP 15-dw0037wm Hard Drive Replacement, Lower Case: step 1, image 2 of 2
      • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Set the laptop down with the lower case facing up.
      • Lift a corner of the lower silicone foot and peel it completely off.
      • Repeat for the upper silicone foot.
      Ask FixBot
    2. HP 15-dw0037wm Hard Drive Replacement: step 2, image 1 of 2 HP 15-dw0037wm Hard Drive Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the five 8 mm screws.
      • Remove the two 5 mm Phillips screws.
      Ask FixBot
    3. HP 15-dw0037wm Hard Drive Replacement: step 3, image 1 of 3 HP 15-dw0037wm Hard Drive Replacement: step 3, image 2 of 3 HP 15-dw0037wm Hard Drive Replacement: step 3, image 3 of 3
      • Insert an opening pick into the gap between the lower case and chassis.
      • Starting from a corner is recommended.
      • Slide the pick around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 15-dw0037wm Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 HP 15-dw0037wm Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 HP 15-dw0037wm Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • Remove the two 4 mm Phillips screws on the metal bracket.
      • Remove the one 4 mm Phillips screw that secures the board attached to the hard drive.
      Ask FixBot
    2. HP 15-dw0037wm Hard Drive Replacement: step 5, image 1 of 3 HP 15-dw0037wm Hard Drive Replacement: step 5, image 2 of 3 HP 15-dw0037wm Hard Drive Replacement: step 5, image 3 of 3
      • Gently lift up the black ZIF locking flap.
      • Disconnect the ribbon cable.
      Ask FixBot
    3. HP 15-dw0037wm Hard Drive Replacement: step 6, image 1 of 2 HP 15-dw0037wm Hard Drive Replacement: step 6, image 2 of 2
      • Lift up the hard drive.
      • Remove the single 4 mm screw that secures the metal bracket to the hard drive.
      • The one screw for this one is thicker than the others, 3 mm compared to 2 mm.
      Ask FixBot
    4. HP 15-dw0037wm Hard Drive Replacement: step 7, image 1 of 3 HP 15-dw0037wm Hard Drive Replacement: step 7, image 2 of 3 HP 15-dw0037wm Hard Drive Replacement: step 7, image 3 of 3
      • Pull the metal bracket down slightly and pull to the side.
      • Gently grab the board and pull it to the side.
      • Don't pull down to remove the chip as it can badly damage the port.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 46
All Time: 598
