HP 15-dw Rubber Feet Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
110
All Time:
1,189
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace one or both of the rubber feet on your HP 15s Laptop PC.
Note: This procedure was written using a model 15-dw3033dx HP 15s Laptop PC, but is fully compatible with any HP 15s Laptop PC whose model number starts with 15-dw.
Tools
  • Tesa 61395 Double-Sided Tape
    4.9
    Optional
    1. HP 15-dw Rubber Feet Replacement, Flip your laptop over: step 1, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP 15-dw Rubber Feet Replacement, Peel up an end of the front foot: step 2, image 1 of 3 HP 15-dw Rubber Feet Replacement, Peel up an end of the front foot: step 2, image 2 of 3 HP 15-dw Rubber Feet Replacement, Peel up an end of the front foot: step 2, image 3 of 3
      • The rubber feet cover a total of five back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
      Ask FixBot
    3. HP 15-dw Rubber Feet Replacement, Remove the front foot: step 3, image 1 of 3 HP 15-dw Rubber Feet Replacement, Remove the front foot: step 3, image 2 of 3 HP 15-dw Rubber Feet Replacement, Remove the front foot: step 3, image 3 of 3
      • Peel the front foot away from the back cover and remove it.
      Ask FixBot
    4. HP 15-dw Rubber Feet Replacement, Remove the rear foot: step 4, image 1 of 3 HP 15-dw Rubber Feet Replacement, Remove the rear foot: step 4, image 2 of 3 HP 15-dw Rubber Feet Replacement, Remove the rear foot: step 4, image 3 of 3
      • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
      • Peel the rear foot away from the back cover and remove it.
      Ask FixBot
    5. HP 15-dw Rubber Feet Replacement, Reassembly information: step 5, image 1 of 3 HP 15-dw Rubber Feet Replacement, Reassembly information: step 5, image 2 of 3 HP 15-dw Rubber Feet Replacement, Reassembly information: step 5, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Note that the rubber feet are different:
      • The front foot is thicker, with a deeper recess.
      • The rear foot is thinner, with a shallower recess.
      • During reassembly:
      • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
      • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
      • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
      • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
      Ask FixBot
Spencer Day
206,618 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 110
All Time: 1,189
