HP 15-dw Back Cover Replacement
    1. HP 15-dw Back Cover Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
      • Fully shut down your laptop and unplug all cables.
      Ask FixBot
    1. HP 15-dw Back Cover Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. HP 15-dw Back Cover Replacement, Peel up an end of the front foot: step 3, image 1 of 3 HP 15-dw Back Cover Replacement, Peel up an end of the front foot: step 3, image 2 of 3 HP 15-dw Back Cover Replacement, Peel up an end of the front foot: step 3, image 3 of 3
      • The rubber feet cover a total of five back cover screws.
      • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
      • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
      Ask FixBot
    3. HP 15-dw Back Cover Replacement, Remove the front foot: step 4, image 1 of 3 HP 15-dw Back Cover Replacement, Remove the front foot: step 4, image 2 of 3 HP 15-dw Back Cover Replacement, Remove the front foot: step 4, image 3 of 3
      • Peel the front foot away from the back cover and remove it.
      Ask FixBot
    4. HP 15-dw Back Cover Replacement, Remove the rear foot: step 5, image 1 of 3 HP 15-dw Back Cover Replacement, Remove the rear foot: step 5, image 2 of 3 HP 15-dw Back Cover Replacement, Remove the rear foot: step 5, image 3 of 3
      • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
      • Peel the rear foot away from the back cover and remove it.
      Ask FixBot
    5. HP 15-dw Back Cover Replacement, Reassembly information: step 6, image 1 of 3 HP 15-dw Back Cover Replacement, Reassembly information: step 6, image 2 of 3 HP 15-dw Back Cover Replacement, Reassembly information: step 6, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Note that the rubber feet are different:
      • The front foot is thicker, with a deeper recess.
      • The rear foot is thinner, with a shallower recess.
      • During reassembly:
      • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
      • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
      • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
      • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
      Ask FixBot
    1. HP 15-dw Back Cover Replacement, Unfasten the back cover: step 7, image 1 of 2 HP 15-dw Back Cover Replacement, Unfasten the back cover: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the seven screws securing the back cover:
      • Five 8.5 mm-long screws
      • Two 4.6 mm-long screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      Ask FixBot
    2. HP 15-dw Back Cover Replacement, Open your laptop: step 8, image 1 of 3 HP 15-dw Back Cover Replacement, Open your laptop: step 8, image 2 of 3 HP 15-dw Back Cover Replacement, Open your laptop: step 8, image 3 of 3
      • Flip your laptop over and open the screen.
      Ask FixBot
    3. HP 15-dw Back Cover Replacement, Release the clips: step 9, image 1 of 2 HP 15-dw Back Cover Replacement, Release the clips: step 9, image 2 of 2
      • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
      • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
      • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
      Ask FixBot
    4. HP 15-dw Back Cover Replacement: step 10, image 1 of 2 HP 15-dw Back Cover Replacement: step 10, image 2 of 2
      • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
      • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
      Ask FixBot
    5. HP 15-dw Back Cover Replacement: step 11, image 1 of 3 HP 15-dw Back Cover Replacement: step 11, image 2 of 3 HP 15-dw Back Cover Replacement: step 11, image 3 of 3
      • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
      • Slide the opening pick to the bottom left corner to release the remaining clips.
      Ask FixBot
    6. HP 15-dw Back Cover Replacement, Flip your laptop over: step 12, image 1 of 3 HP 15-dw Back Cover Replacement, Flip your laptop over: step 12, image 2 of 3 HP 15-dw Back Cover Replacement, Flip your laptop over: step 12, image 3 of 3
      • Close the screen and flip your laptop back over.
      Ask FixBot
    7. HP 15-dw Back Cover Replacement, Remove the back cover: step 13, image 1 of 3 HP 15-dw Back Cover Replacement, Remove the back cover: step 13, image 2 of 3 HP 15-dw Back Cover Replacement, Remove the back cover: step 13, image 3 of 3
      • Remove the back cover.
      • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
      Ask FixBot
Spencer Day
206,396 Reputation
1,268 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 58
Past 30 Days: 212
All Time: 5,550
