This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
HP 15-db0027nf Battery Replacement
    1. HP 15-db0027nf Battery Replacement, Bottom case: step 1, image 1 of 2 HP 15-db0027nf Battery Replacement, Bottom case: step 1, image 2 of 2
      • Remove the feet with a spudger.
      Ask FixBot
    2. HP 15-db0027nf Battery Replacement: step 2, image 1 of 2 HP 15-db0027nf Battery Replacement: step 2, image 2 of 2
      • Remove the 11 Phillips screws using a PH0 screwdriver.
      • The screws are identical.
      Ask FixBot
    3. HP 15-db0027nf Battery Replacement: step 3, image 1 of 2 HP 15-db0027nf Battery Replacement: step 3, image 2 of 2
      • Insert a spudger between the bottom of the frame and the keyboard plate, and go around the computer to unclip the computer cover.
      • Remove the bottom cover from the computer.
      Ask FixBot
    4. HP 15-db0027nf Battery Replacement: step 4, image 1 of 1
      • You now have access to the inside of the machine.
      Ask FixBot
    1. HP 15-db0027nf Battery Replacement, Battery: step 5, image 1 of 1
      • Remove the 3 screws that keep the battery in place, using a Phillips screwdriver.
      Ask FixBot
    2. HP 15-db0027nf Battery Replacement: step 6, image 1 of 1
      • Unplug the battery by gently lifting it.
      • Don't lift the battery too forcefully, as it is held by notches on the opposite side of the connector.
      • Pull the battery toward the top of the computer to dislodge it.
      Ask FixBot
To put your device back together, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,455 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 78
All Time: 649
