HP 15-db0015dx USB/SD Card Reader Replacement
    1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: step 1, image 1 of 2 HP 15-db0015dx USB/SD Card Reader Replacement, Battery: step 1, image 2 of 2
      • Power off the device before starting.
      • Remove the rubber strips that hide the screws using the spudger.
      • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. HP 15-db0015dx USB/SD Card Reader Replacement: step 2, image 1 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 2, image 2 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 2, image 3 of 3
      • Use the spudger tool to pry open the back cover.
      • Lift the back panel to access the inside.
      • Slide the CD drive to the left, and remove.
      Ask FixBot
    3. HP 15-db0015dx USB/SD Card Reader Replacement: step 3, image 1 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 3, image 2 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 3, image 3 of 3
      • Unscrew the three battery screws with a Phillips #0 screwdriver.
      • Lift the battery up, disconnecting the connector first.
      • Push forward and remove the battery.
      Ask FixBot
    1. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: step 4, image 1 of 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: step 4, image 2 of 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: step 4, image 3 of 3
      • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
      • Pull the hard drive bracket out.
      Ask FixBot
    2. HP 15-db0015dx USB/SD Card Reader Replacement: step 5, image 1 of 1
      • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
      Ask FixBot
    1. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: step 6, image 1 of 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: step 6, image 2 of 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: step 6, image 3 of 3
      • Lift up on the connector pin that attaches the SD card reader to the motherboard
      • Gently pull the wire out
      Ask FixBot
    2. HP 15-db0015dx USB/SD Card Reader Replacement: step 7, image 1 of 2 HP 15-db0015dx USB/SD Card Reader Replacement: step 7, image 2 of 2
      • Snake the wire underneath the battery support
      • Pull the wire out to allow the SD Card reader to be removed
      Ask FixBot
    3. HP 15-db0015dx USB/SD Card Reader Replacement: step 8, image 1 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 8, image 2 of 3 HP 15-db0015dx USB/SD Card Reader Replacement: step 8, image 3 of 3
      • Remove the two Phillips #0 screws holding the SD Card reader in place.
      • Gently pull the SD card reader up and out of the slot.
      • A spudger may have to be used to pop the SD card reader out of place.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 845
