HP 15-db0015dx RAM Replacement
    1. HP 15-db0015dx RAM Replacement, Battery: step 1, image 1 of 2 HP 15-db0015dx RAM Replacement, Battery: step 1, image 2 of 2
      • Power off the device before starting.
      • Remove the rubber strips that hide the screws using the spudger.
      • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. HP 15-db0015dx RAM Replacement: step 2, image 1 of 3 HP 15-db0015dx RAM Replacement: step 2, image 2 of 3 HP 15-db0015dx RAM Replacement: step 2, image 3 of 3
      • Use the spudger tool to pry open the back cover.
      • Lift the back panel to access the inside.
      • Slide the CD drive to the left, and remove.
      Ask FixBot
    3. HP 15-db0015dx RAM Replacement: step 3, image 1 of 3 HP 15-db0015dx RAM Replacement: step 3, image 2 of 3 HP 15-db0015dx RAM Replacement: step 3, image 3 of 3
      • Unscrew the three battery screws with a Phillips #0 screwdriver.
      • Lift the battery up, disconnecting the connector first.
      • Push forward and remove the battery.
      Ask FixBot
    1. HP 15-db0015dx RAM Replacement, RAM: step 4, image 1 of 1
      • Locate the RAM.
      Ask FixBot
    2. HP 15-db0015dx RAM Replacement: step 5, image 1 of 3 HP 15-db0015dx RAM Replacement: step 5, image 2 of 3 HP 15-db0015dx RAM Replacement: step 5, image 3 of 3
      • Pull the gray clips holding the RAM to the sides.
      • This will cause the RAM to pop out at an angle.
      • Remove the RAM.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 103
All Time: 4,354
