HP 15-db0004dx Bottom Case Replacement
    1. HP 15-db0004dx Bottom Case Replacement, Bottom Case: step 1, image 1 of 2 HP 15-db0004dx Bottom Case Replacement, Bottom Case: step 1, image 2 of 2
      • Turn the laptop off and unplug it before starting.
      • Flip your laptop over, face down.
      Ask FixBot
    2. HP 15-db0004dx Bottom Case Replacement: step 2, image 1 of 1
      • Peel off the two long rubber grips running lengthwise on the laptop.
      Ask FixBot
    3. HP 15-db0004dx Bottom Case Replacement: step 3, image 1 of 2 HP 15-db0004dx Bottom Case Replacement: step 3, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
      Ask FixBot
    4. HP 15-db0004dx Bottom Case Replacement: step 4, image 1 of 1
      • Carefully slide the optical drive out of the laptop.
      Ask FixBot
    5. HP 15-db0004dx Bottom Case Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to separate the back panel from the laptop.
      • For an easier removal, start at the corner and run the tool along the edge of the cover.
      • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
      • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 78
All Time: 714
