HP 15-da0012dx Screen Replacement
    1. HP 15-da0012dx Screen Replacement, Battery: step 1, image 1 of 2 HP 15-da0012dx Screen Replacement, Battery: step 1, image 2 of 2
      • Power down your laptop before proceeding.
      • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
      Ask FixBot
    2. HP 15-da0012dx Screen Replacement: step 2, image 1 of 3 HP 15-da0012dx Screen Replacement: step 2, image 2 of 3 HP 15-da0012dx Screen Replacement: step 2, image 3 of 3
      • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
      Ask FixBot
    3. HP 15-da0012dx Screen Replacement: step 3, image 1 of 2 HP 15-da0012dx Screen Replacement: step 3, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
      Ask FixBot
    4. HP 15-da0012dx Screen Replacement: step 4, image 1 of 2 HP 15-da0012dx Screen Replacement: step 4, image 2 of 2
      • Slide the optical drive out of the computer.
      Ask FixBot
    5. HP 15-da0012dx Screen Replacement: step 5, image 1 of 3 HP 15-da0012dx Screen Replacement: step 5, image 2 of 3 HP 15-da0012dx Screen Replacement: step 5, image 3 of 3
      • Flip the computer over and open the screen.
      • Start from a corner and run the plastic opening tools along the edge of the back cover.
      • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
      • Gently pry back the cover starting from the middle, bottom edge.
      • Make sure not to bend or crack the plastic cover.
      Ask FixBot
    6. HP 15-da0012dx Screen Replacement: step 6, image 1 of 2 HP 15-da0012dx Screen Replacement: step 6, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
      Ask FixBot
    7. HP 15-da0012dx Screen Replacement: step 7, image 1 of 2 HP 15-da0012dx Screen Replacement: step 7, image 2 of 2
      • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
      Ask FixBot
    1. HP 15-da0012dx Screen Replacement, Screen: step 8, image 1 of 2 HP 15-da0012dx Screen Replacement, Screen: step 8, image 2 of 2
      • Remove the 3 mm Phillips #0 screw securing the WLAN card in place.
      • Carefully remove the WLAN card from the motherboard.
      • Gently remove the antenna cable from the wire guides in the speaker and chassis.
      • Place WLAN card off to the side being careful not to pull on the antenna cable.
      • The antenna cable is soft and can easily be damaged.
      Ask FixBot
    2. HP 15-da0012dx Screen Replacement: step 9, image 1 of 3 HP 15-da0012dx Screen Replacement: step 9, image 2 of 3 HP 15-da0012dx Screen Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully use the metal tweezers to remove the display connection to the motherboard.
      Ask FixBot
    3. HP 15-da0012dx Screen Replacement: step 10, image 1 of 3 HP 15-da0012dx Screen Replacement: step 10, image 2 of 3 HP 15-da0012dx Screen Replacement: step 10, image 3 of 3
      • Use the Phillips #1 screwdriver to disconnect the display hinges from the base of the laptop.
      Ask FixBot
    4. HP 15-da0012dx Screen Replacement: step 11, image 1 of 2 HP 15-da0012dx Screen Replacement: step 11, image 2 of 2
      • Making sure to hold both the base and the screen, partially open laptop.
      • Carefully remove screen from laptop, making sure that the WLAN card is safely removed with it.
      Ask FixBot
    5. HP 15-da0012dx Screen Replacement: step 12, image 1 of 3 HP 15-da0012dx Screen Replacement: step 12, image 2 of 3 HP 15-da0012dx Screen Replacement: step 12, image 3 of 3
      • Carefully use the pry tool to separate the screen side of the hinge cover from the screen.
      • Rotate the hinge cover away from the screen to remove it from the screen.
      Ask FixBot
    6. HP 15-da0012dx Screen Replacement: step 13, image 1 of 3 HP 15-da0012dx Screen Replacement: step 13, image 2 of 3 HP 15-da0012dx Screen Replacement: step 13, image 3 of 3
      • Starting from the area near the hinges, gently remove the adhesive display bezel from around the screen using the iFixit opening tool.
      Ask FixBot
    7. HP 15-da0012dx Screen Replacement: step 14, image 1 of 2 HP 15-da0012dx Screen Replacement: step 14, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the four 3.0 mm screws securing the screen to the top cover.
      Ask FixBot
    8. HP 15-da0012dx Screen Replacement: step 15, image 1 of 2 HP 15-da0012dx Screen Replacement: step 15, image 2 of 2
      • Carefully lift the screen, being aware to not pull on the display cable connecting the screen to the top cover.
      • Gently remove the display cable from the back of the screen.
      • Remove the screen from the display assembly.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 106
All Time: 4,822
