Up to 20% off select tools
HP 15-da0002dx RAM Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
81
All Time:
2,014
Comments: 4
4 comments on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If your HP 15-da0002dx laptop is running slowly, freezing, reboots, or brings up a blue screen, use this guide to replace the RAM. The purpose of the RAM is to run data and access the storage device.
Before using this guide, always make sure the RAM being replaced is compatible with your motherboard. Power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
    1. HP 15-da0002dx RAM Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the computer is completely turned off.
      Ask FixBot
    2. HP 15-da0002dx RAM Replacement: step 2, image 1 of 1
      • Turn over the laptop.
      • The HP label should be touching the table and the bottom cover should be facing up.
      Ask FixBot
    3. HP 15-da0002dx RAM Replacement: step 3, image 1 of 2 HP 15-da0002dx RAM Replacement: step 3, image 2 of 2
      • Two plastic feet are located on adjacent sides of the back cover.
      • Peel back the plastic feet using the plastic opening tools.
      Ask FixBot
    4. HP 15-da0002dx RAM Replacement: step 4, image 1 of 1
      • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
      Ask FixBot
    5. HP 15-da0002dx RAM Replacement: step 5, image 1 of 1
      • Carefully flip over the computer so the HP label is now facing the ceiling.
      Ask FixBot
    6. HP 15-da0002dx RAM Replacement: step 6, image 1 of 2 HP 15-da0002dx RAM Replacement: step 6, image 2 of 2
      • Open the screen.
      • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
      Ask FixBot
    7. HP 15-da0002dx RAM Replacement: step 7, image 1 of 1
      • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
      Ask FixBot
    1. HP 15-da0002dx RAM Replacement, Battery: step 8, image 1 of 1
      • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP 15-da0002dx RAM Replacement: step 9, image 1 of 2 HP 15-da0002dx RAM Replacement: step 9, image 2 of 2
      • Using your fingers, tilt the top part of the battery towards you.
      • Continue to pull the rest of the battery away from the mounting tabs to remove.
      Ask FixBot
    1. HP 15-da0002dx RAM Replacement, RAM: step 10, image 1 of 1
      • The retention clips are located on either side of the RAM module. Spread them away from each other until you hear a clicking sound.
      Ask FixBot
    2. HP 15-da0002dx RAM Replacement: step 11, image 1 of 2 HP 15-da0002dx RAM Replacement: step 11, image 2 of 2
      • Pull the RAM module away from the slot.
      Ask FixBot
8 other people completed this guide.
Author
with
Abigail Aron
1,151 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 81
All Time: 2,014
