HP 15-da0002dx Battery Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
80
All Time:
5,400
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If the HP 15-da0002dx is not charging correctly or only works when plugged in, follow these to replace the battery.
The battery powers the computer and allows it to be used without a power cord. A faulty battery can lead to improper charging and low battery life. Before replacing the battery, make sure your computer’s software is up to date by visiting the latest Official Hp Website. Also be sure to check if the power adapter being used is the correct power adaptor for your computer. Visit the HP-da0002dx troubleshooting page for more information on software and power adaptor solutions.
Before using this guide, power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
Tools
    1. HP 15-da0002dx Battery Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the computer is completely turned off.
      Ask FixBot
    2. HP 15-da0002dx Battery Replacement: step 2, image 1 of 1
      • Turn over the laptop.
      • The HP label should be touching the table and the bottom cover should be facing up.
      Ask FixBot
    3. HP 15-da0002dx Battery Replacement: step 3, image 1 of 2 HP 15-da0002dx Battery Replacement: step 3, image 2 of 2
      • Two plastic feet are located on adjacent sides of the back cover.
      • Peel back the plastic feet using the plastic opening tools.
      Ask FixBot
    4. HP 15-da0002dx Battery Replacement: step 4, image 1 of 1
      • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
      Ask FixBot
    5. HP 15-da0002dx Battery Replacement: step 5, image 1 of 1
      • Carefully flip over the computer so the HP label is now facing the ceiling.
      Ask FixBot
    6. HP 15-da0002dx Battery Replacement: step 6, image 1 of 2 HP 15-da0002dx Battery Replacement: step 6, image 2 of 2
      • Open the screen.
      • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
      Ask FixBot
    7. HP 15-da0002dx Battery Replacement: step 7, image 1 of 1
      • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
      Ask FixBot
    1. HP 15-da0002dx Battery Replacement, Battery: step 8, image 1 of 1
      • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP 15-da0002dx Battery Replacement: step 9, image 1 of 2 HP 15-da0002dx Battery Replacement: step 9, image 2 of 2
      • Using your fingers, tilt the top part of the battery towards you.
      • Continue to pull the rest of the battery away from the mounting tabs to remove.
      Ask FixBot
5 other people completed this guide.
Abigail Aron
1,124 Reputation
5 Guides authored
1 Guide Comment
Where to find, buy the same battery spare???
Divya Lekha - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 80
All Time: 5,400
