HP 15-da0002dx Back Cover Replacement
    1. HP 15-da0002dx Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the computer is completely turned off.
      Ask FixBot
    2. HP 15-da0002dx Back Cover Replacement: step 2, image 1 of 1
      • Turn over the laptop.
      • The HP label should be touching the table and the bottom cover should be facing up.
      Ask FixBot
    3. HP 15-da0002dx Back Cover Replacement: step 3, image 1 of 2 HP 15-da0002dx Back Cover Replacement: step 3, image 2 of 2
      • Two plastic feet are located on adjacent sides of the back cover.
      • Peel back the plastic feet using the plastic opening tools.
      Ask FixBot
    4. HP 15-da0002dx Back Cover Replacement: step 4, image 1 of 1
      • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
      Ask FixBot
    5. HP 15-da0002dx Back Cover Replacement: step 5, image 1 of 1
      • Carefully flip over the computer so the HP label is now facing the ceiling.
      Ask FixBot
    6. HP 15-da0002dx Back Cover Replacement: step 6, image 1 of 2 HP 15-da0002dx Back Cover Replacement: step 6, image 2 of 2
      • Open the screen.
      • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
      Ask FixBot
    7. HP 15-da0002dx Back Cover Replacement: step 7, image 1 of 1
      • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
      Ask FixBot
4 other people completed this guide.
Abigail Aron
1,124 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 7,526
